Sorry to read about your problem, I hope this helps you out.
Your F2 means that the temperature in the oven reached over 590 degrees Fahrenheit with the door unlocked or 930 degrees Fahrenheit with the door locked.
First you need to check the sensor, disconnect power, pull the range or oven out then take off the back cover. Once off you should see the two small wires that are from the sensor then you need to disconnect them (some have a plug but if you have to cut the wires).
Now using your ohmmeter , measure resistance between the wires going to the sensor. It should be somewhere between 1050 and 1150 ohms. Note that this test should be done while the oven is at room temperature. If the resistance is not within the range mentioned above, then replace the sensor. If resistance is within range, replace the control board.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
F2 error is a bad temperature sensor in the oven.
It must be replaced.
