E-Machines T6216 (827103077834) PC Desktop Logo
Posted on Dec 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for video card suggestion. have t6216 w/896mb RAM
joecoolvette
Level 3:
  • E-Machines Master 5,660 Answers
  • Posted on Apr 10, 2011
joecoolvette
E-Machines Master
Level 3:
Answers
5660
Questions
0
Helped
2192881
Points
18014
I would recommend an Nvidia GeForce GT240 graphics card with 1GB (1024MB) of graphics ram memory.
A) Your stock Power Supply will work.
B) It has 1GB of ram memory.
C) It has 96 Stream Processors.
D) 128-bit interface.
E) 550MegaHertz Core Clock
F) 1800MHz Memory Clock
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5467136&CatId=3669
I would also recommend bumping the Ram Memory up to 2GB, instead of 896MB.
Regards,
joecoolvette
  • joecoolvette
    joecoolvette Apr 10, 2011
    Sorry drewworld, don't know how this solution bumped up in the que. Should be the second in the que. joecoolvette
  • joecoolvette
    joecoolvette Apr 12, 2011
    Thank you for the rating Bill, Most Appreciated!
Anonymous
Level 1:
  • Contributor 1 Answer
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
167
Points
I have a 7300gt nvidea in mine right now... ok, but not the best. runs dx9. and it helps to get the bios update from the emachines site to help with nvidea compatibility. To run most games now, you might need more ram, and for the price, a barebones with your old parts thrown in might be a better deal. The 7300gt is pretty cheap if you are just looking for a quick cheap upgrade for now. It works with the original 300 watt psu and works ok for me with 2.5 gb ram (2-4 gb extra ram realllly helps!). I think tiger direct has some nice deals on barebones and cards, it kinda changes daily.
1helpful
2answers
Hp a705w upgraded to 2gb ram, 160gb hd (sata) cpu running at 2.93gh,\r\nshould be a beast. runns slow and video streaming has slight freeze. HELP. Welcom291
the specs is already good for browsing and some sort of document editing. however, if you wish to play games or do video editing, i suggest you get a good video card. 1gb video card will be good. Even if you have a good amount of ram but your video processing memory is shared, it will definitely slow your computer.
~josh
2answers
Hi, When I switch on my computer, I am not gettging the dsiplay on my monitor. My monitor is working with other desktop. My RAM is working fine. It seems my board inbuilt VGA card is gone. How do I replace...
You can install a video card in the AGP expansion slot to replace the faulty on-board video. When you connect the monitor to the new video card it should boot uo with the generic VGA video driver, then you need to install the video driver (CD) that was supplied with the video card, then you can the screen resolution to 1024X768 or higher to suit your tastes.
I am trying to find a video card to upgrade my Dell c610 the card is currently 16Mb. Any suggestions?
I'm sorry to advise you, your Dell is a laptop and laptops have a built-in video chip on the motherboard and it cannot be upgraded or changed.
The video card used shared RAM, ie it uses part of the main RAM module/s, You maybe be able to increase the video RAM size in the BIOS, but this will reduce the main memory, so you might want to upgrade the RAM in the DELL.
You only other alternative is to buy a later model laptop.
1helpful
Suggest me best 256mb graphics card @decent price in india!
well my suggesion for RAm are 4GB and and any lowprice PCI-E card like 8500GT would be nice
2answers
LCD panel broken will not run seperate monitor
Best looking for new motherboard on Ebay.
www.ebay.com
Gateway E-3200 no video signal
hi! there,
there are common factors why no video on your screen.,right one factor is ram,the other are video card,processor and monitor
you can't trouble shoot with out other computer available,tester cann't detected all this,it make easy to parts to parts.disconnect cd room,hardisk and floopy also disconnect your video card and memory card put video card and ram one by one (if youhave nultiple ran) to other computer ,be sure other computer is run good and observed, if no video take the previous video card and put back if there video,possible your video card is busted,or try to put other video card and ram to your pc be sure this are good,if ok select your own part that you think is busted since you said your ram is good,put back to your pc observed.....replace aby busted parts,
take all precaution avoid electric shock wear safety shoes.regards and have a nice day
Video Controller
install video card driver
2answers
Cricket07 and NFS underground not running on my pc
how much memory does your video card have I suggest you add more ram and a bigger memory video card it sound like your computer is using your hard drive as temporary memory
Mother board problem
sounds like video card driver issue...ensure driver is correct by looking at video card in device manager. Also ensure that system interrupts are being allocated properly.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
