The voice on this product was once fine and now it sounds garbled and as if it has a short somewhere. While giving directions it cuts off and when I use the Bluetooth capabilities for my phone the calls usually disconnect. I certainly hope there is a simple solution to this as I rely on this product and spent a lot for this particular model thinking it would last and was a quality product. Can you please advise? Thank you VERY much.
SOURCE: voice not working properly on garmin nuvi 660 - very disdorted
i have been told that voice to street is not as clear as the voice just stating turns. If it really bothers you then try voice to turn. I cant remember the setting but it should work well for you.
SOURCE: garmin nuvi won't turn on
Well , do you delete or add something in your NUVI before that occured.
Need more information.
Is that a new problem ?
What is the lassfrimware update ?
SOURCE: Garmin Nuvi 660 - how do I get FM Transmitter firmware
Yes, you can purchase an external FM modulator like those used on IPOD's and CD players. I am using one on my Nuvi 350 and it works well. Just plug it into the headphone jack. Advice: Be sure to buy one that is crystal (PLL) controlled and NOT using a tuning dial. The FM modulators that use a tuning dial often tend to drift and they will also change frequency when you hit a bump in the road.
Good Luck!
- Jim
SOURCE: Garmin 660 gps Bluetooth problem
Note: This is for a 550c Street pilot
1) Turn on unit
2) Press VIEW MAP
3) Press SPEED in lower left hand side of map
4) This will bring you to the Trip meter screen on this screen press the round speedometer at the top of the screen for about 10 seconds this will bring you to the SYSTEM BIOS.
5) From this point forward be careful you can mess up your unit by changing the wrong thing.
6) Press NEXT until you come to the BLUETOOTH STATUS screen.
7) Now press UPDT P this should complete your update.
SOURCE: Garmin 760 - No Voice Directions
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Common problem is the speakers go bad and needs replaced. Please see here for a solution.http://www.sharc.net/gps_audio_repair.ht...
