Sirius SUBX1 Universal Plug and Play Boom Box Boombox Logo
Posted on Dec 25, 2010
I just purchased a boombox dock station for my onyx xm radio and hooked everything up shows signal artists songs everything. only problem is there is no audio. xm customer service is no help at all do you guys know how to fux my problem ive tried playing in the menus the volume knob just keeps twisting.
Rumple Stiltzken
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 23, 2015
Rumple Stiltzken
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1667
Points
There is a setting in the radio to switch the audio to the different holder
Anonymous
Level 1:
New Friend:
  • Posted on Jan 23, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1667
Points
I'm having the same issue and need a solution
Larry Alex
Level 1:
Habit-Forming:
  • Contributor 10 Answers
  • Posted on Dec 07, 2011
Larry Alex
Contributor
Level 1:
Habit-Forming:
Answers
10
Questions
0
Helped
11068
Points
21
Yes, the boombox works with a Sirius radio, but the XM Onyx has all the signs it's working, except no audio. If I could only get to the audio output, I'd use the AUX in, but the dock appears to make this impossible. Frustrating...
  • Larry Alex Apr 27, 2015
    OK RS. That would be great news. Can you explain how this setting in the XM Onyx radio works to switch the audio to the Sirius holder?
Anonymous
Level 1:
New Friend:
  • Posted on May 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1667
Points
Having same issue. So apparently the onyx may not work with the subx1. I enjoy my boombox and maybe a solution will come soon.
Skydock won't play iTunes through the radio like it does for the satellite radio. The song plays but no sound comes from anything other than the XM Skydock App.
hi donald!
it seems like you haven't properly installed the sky dock yet.
can you tell me the model of the sky dock you purchased?
Cannot power up xm onyx radio in docking station; will turn on when not in docking station..what's wrong?
I had the same problem, Bought a new Onyx and tried the supplied 12v power cable on existing Onyx and it worked, So it appears to be the power cable, Hoping now I can find a new power cable,
Can't hear anything on my radio. Had XM resend the satellite signal. It shows that I'm getting the signal, but athere is no sound coming out of my radio. I checked all the wires and everything is fine.
check your settings and see if the line out level is up. If it has one. try plugging in headphones into the line out plug. If the headphones work then your line out cable is bad. there should be some type of volume control on your radio. If you can see the channel name and the description of the song artist and title then you should be getting sound
Does not work when docked in boombox,not getting
the "reactivate" did not take in it's entirety, try calling sirus/XM again and see if they will "reboot it again, this time try having it the docking station within antenna "range", and both should "reboot", let me know if this fixes the problem, if not I have some friends there I can call, and we'll go from there, god bless and happy 4th......
Xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
No signal
Here is a site that cares a lot of sat. radio things
http://www.xm-radio-satellite.com/
This maybe what you are looking for a "Delphi XM Radio Wireless Signal Repeater System"
XM Roady is non functional
turn ignition on and disconnect your car battery then leave it on until its done loading if it still there then call xm and have then send an update good luck....
No sound from SUBX1 boombox
Be sure all is charged and connected to power correctly. Next the only other thing you can really do is to clean the connections on the device and the dock useing denatured(rubbing)alcohol and q-tips. This should help. Good Luck
P.S. Make sure all the settings are correct both on the dock and the xm - radio. Sometimes there are settings that can be off. Good Luck
Ipod wont work
The problem is "ipod dock receiver connector"(connector is fuck), move forward and backwards the ipod just point the ipod can play the songs..
try you!
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
