Video Cameras Logo
A
Anonymous Posted on Dec 25, 2010
Charge adapter - Samsung Video Cameras
Anonymous
Level 3:
Genius:
  • Master 1,177 Answers
  • Posted on Dec 25, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1177
Questions
0
Helped
218993
Points
3782
Not enough information in your query. I don't know what camera you have or what your problem is exactly.
If you are looking for a new mains adapter or charger, you can usually find one by searching on Amazon for the model of your camera plus the word "charger". If the camera uses a small lithium battery, there are "Universal" chargers that can be adjusted to fit any of the small batteries used in cameras and phones (though not the really big batteries used in older tape based camcorders).
These are quite cheap, as little as $4 US.
My Dell Inspiron 3520 laptop is not charging, the charger/adapter is not working. I cannot fix it, bought new battery and adapter and they do not charge. What do I do?
Is the plug that you connect the adapter to still properly connected to the mo bo? If not, the adapter will not work nor will it properly charge the battery. Bet that if you charge that battery to another working laptop your new battery will take a charge.
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
When I put my into an adapter for charging it does not light up or show me when it is done charging. How will I know when it is fully charged?
Is the charger actually working and providing a current to go into your GPS? If you operate the unit without the adapter the battery indicator should reflect a low state and then change when you plug in the adapter. If it still stays low after plugging in adapter, either the adapter is no good or the battery will no longer take a charge.
Nov 21, 2015 • GPS
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Coolpix s3000 wont charge from car usb adapter?
The battery in this camera has to be removed and connect to an AC adapter to be charged.
  • Rechargeable Li-ion Battery EN-EL10
  • Charging AC Adapter EH-68P
3helpful
2answers
My dell inspirion ac charger will keep computer running but will not charge my battery. A pop up will inform me that the system doesnt recognize the charger.
it could be a couple things: Are you using the standard 90 Watt ac adapter, or the Travel auto/Air adapter. The travel adapter is only 65 watts can will charge the battery
If using the standard ac adapter, see if you can try another Dell D series adapter and see if you get the same error.
If same with another adapter, the issue is the charging circuit. If another adapter works, then replace the adapter.
If the charging circuit is bad, it will be the chargerboard or if intergrated, the motherboard
2answers
I have a Epc note book and it will take a charge just received i
You say the laptop battery not charge or the Epc can not work with the adapter?
First you try to charge a fine battery with your adapter to confirm the adapter is good or not.
Then use the good adapter to charge your battery to confirm the battery is dead or not.
You should change your adapter or battery.
Battery won't charge
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook.
NextTag.com has decent deals on these adapters. http://www.nextag.com/ac-adapter-compaq-presario-m2000/search-html
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Charging Adapter
i think your laptop needs 90watt adapter because of that its not charging.....
2answers
How to find replacement adapter for GR-D70AS
Order the original adapter from JVC. The adapter supplies the correct current requirements to operate the battery charge circuit. JVC's web site is JVC.COM. The correct charger will provide up to 1.5 amperes of current for the charge circuit at approx. 11 volts DC. Good Luck Joe Weibel Custom Electronics (customelectronics.org)
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
NOEL
NOEL
 Grubhead
Grubhead
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
