I got the same error message at the beginning of the wash cycle when the unit was attempting to fill with water. Upon researching the issue, I read a lot about the possibility of too much soap causing a blocked sensor. Even though I use HE, I may have been over doing it with the detergent so I started using less. Also, I decided to try pouring a cap-ful or two of hot water in after adding the soap. While I can't vouch for the accuracy of that diagnosis, I can say that I haven't gotten the error since. Hope this helps!
Fsdf
Sorry to read about your problem, I hope this helps you out.
Your F1 means you have a primary control failure.
I suggest you contact a service company.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
