Question about Elna 2007 Mechanical Sewing Machine
Elna machanical sewing machine
I'm using an Elna machanical sewing machine. This machine is probably 50 years old. I was sewing different stitches, change the disc and now the machine only is sewing a straight stitch. I have moved everything, but I can't get it to do any other stitching except straight. Can you help me?
  • Anonymous Mar 29, 2014
    elna 3007
  • 136 Answers
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Posted on Jul 12, 2009
  • sewtexas Sep 12, 2009
    Does the disc turn when you sew? if yes, refer to book to insert disk correctly, being sure width is not on straight stitch. If disk isn''t turning, you have a broken elnagraph gear. This is a repair for an experienced elna mechanic as the top shaft has to be removed and the whole machine must then be retimed. Feed, hook, pendulum timing. Make sure to have trained elna mechanic if you want your machine to sew correctly again
  • 202 Answers
Often these are just stuck from dry grease or oil from non use. A hot blowdryer to the effected areas works wonders softening this up and being able to move again. And penetrating oil also helps.
Posted on Apr 15, 2012
    New Friend:
Do you have a black disc that goes in the top?
Posted on Oct 23, 2009
I have a Elna air electronic 68, I am not able to use different function. Like thr preprogrammed.
Your AE 68 will have three dials across the front, from L-R, stitch selector, stitch width and stitch length. To sew any stitch with a sidewise needle movement, you will need to turn the stitch selector to that stitch on the selector, then turn the stitch width to between 3 and 4 and the stitch length to a similar setting, adjusting to get the stitch formation you need. To sew with the discs, set all the dials to zero, then insert a cam into the Elnagraph on top of the machine. Then turn the selector to the disc icon, and the stitch length around to the "S" and stitch width to 4.
Don't use reverse if using the elnagraph stitches.
Jul 01, 2017 | Elna Sewing Machines
What is the rght tension for The Elna Contessa 410 sewing machine?
Every machine is different, so a "right" tension will vary. The factory standard tension setting is the midway point between high & low number...BUT that needs to be tweaked per your machine.
Skipped stitches? Be sure to use a brand new needle and a needle that is compatible with the thread and fabric you are sewing. (Replacing an old needle is the most common and least expensive fix for a lot of machine problems.)
Optimal tension is when the upper and bobbin threads meet in the middle of the fabric.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Feb 24, 2017 | Elna Sewing Machines
I would like to know what stitch number to put my sewing machine onto to stitch stretch material. I have a Elna 40 sewing machine regards Judy
Looks like stitch #06 might be a stretch stitch. You could probably also use a slight 08 or 09 zig-zag. Unless you are sewing something really stretchy (lycra) IMHO, a slight zig-zag is fine and actually is a lot faster than a stretch stitch which takes a few stitches forward and then one or two stitches in reverse. The stitch #09 is something that I use frequently for stretch fabrics.
Elina 40 Question and Answers
May 31, 2016 | Elna Sewing Machines
I have an Super Elna purchased about 1973. I was using a Double Disc and it stopped working. All the machine does now is sew backwards when I have the disc in. The disc appears not to be moving. It does...
If you have not used the machine for a considerable time or have not used a feature, then the old oil becomes sticky and will eventually "gum up" the mechanism.
The cam (disc) turns all the time when the machine is in use, whether or not the particular stitch that the disc makes is being used. If this is not happening, one (or both) of the gears that drive it is damaged and the machine will need a repair.
Your machine needs a proper service to free off the parts and t investigate the disc problem.
Mar 12, 2015 | Elna Sewing Machines
I have my grans Elna Contessa305, I am no expert sewer but know how to thread a machine correctly. However, the stitching at the bottom keeps getting knotted and making a big mess. I've re-thread
try changing the needle --one that is correct for the fabric being sewed
try a different thread
make sure the bobbin is inserted correctly into the bobbin case
and turned the right way.
make sure the top thread has not come off the thread take up lever
Feb 12, 2013 | Elna Sewing Machines
How to embroider with elna su electronic
There are a couple of Elna SU models, the Star Series SU is white with a blue top panel. Or the air electronic SU is a white machine and a dozen years newer (80's). Both have a disc elnagraph reader in a flap on top of the machine and sew a range of stitches involving either side to side stitch formation or side to side and forwards and backwards, albiet revolutionary when new but not what modern computerised embroidery machines can produce now. To use, you set stitch width and length dials to zero, then insert the black disc into the elnagraph ensuring you line up the disc with a little finger underneath. There should be a red marking on the disc and the shaft to assist with this. Press down until the disc clicks into place. Now turn stitch length to S for supermatic and width to 4 and sew. You can vary the stitch width to adjust stitch and the AE also has a little dial that elongates or closes up the stitch. Try machine embroidery thread for a silky stitch especially with satin stitch where the thread is close together. Also wing needles can be interesting when using the turkish hem stitch disc.
Dec 29, 2012 | Elna Sewing Machines
I used a single cam in my Elna Carina and I can't remove it. help!
ELNA Carina Instruction Manual
Perhaps the spindle where the cam sets needs a drop of good quality sewing machine oil, like Tri-Flow Synthetic Lube. Be sure the stitch length & width are set to Zero.
Elna Carina Electronic SU Duplex Review
How to remove can from an elna Carina Its stuck and can remove it My...
Dec 19, 2017 | Elna 2007 Mechanical Sewing Machine
Older Elna machine-black stitch discs, how do I use them
These discs are either single or double discs, the doubles give forwards and backwards movement by the feed dogs moving the fabric as well as side to side movement of the needle. This gives you the "Supermatic" stitches, revolutionary in 1952 when Elna developed this technology.
I'm assuming that you have a Supermatic (green) or Star Series SU (white with blue top) Elna model? your model will have a code number on the side plate by the power point, it may be 62 if its a Star, there is some variation in how you select the automatic stitches between these models but the basics are similar.
Start first by turning the stitch width selector to zero and stitch length selector to zero.
You need to insert the disc into the Elnagraph carefully, lining up the dot marking on the disc with the finger within the elnagraph, there is a little hole underside of the disc where this finger goes into to lock the disc in place. You now turn the stitch selector to "A" for automatic, and turn the stitch width to 4. Always turn your dials back to zero before removing the disc as there is a little feeler that swings over to "read" off the disc and you won't want to damage this.
The very early Elna supermatic take a slightly different disc, the finger hole is slightly different to the later machines and they were removed using a little tool. Later models it got easier and you push the middle of the elnagraph silver ring to release the disc.
I hope I haven't confused you more, you may want to join the Swiss Elna user group called Elna Heirlooms under yahoo.com groups, its a very helpful group of members and you should find a thread on these machines there.
Mar 18, 2012 | Elna Sewing Machines
Have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Mar 11, 2009 | Elna 1010
Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Jan 31, 2008 | Elna 2007 Mechanical Sewing Machine
Elna 2007 Mechanical Sewing Machine Logo
381 people viewed this question
Top Elna Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
Douglas Plant
Douglas Plant
Elation Relation
Level 1 Expert
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
