Question about RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer
My paslode angled finishing gun keeps jamming leaving the firing pin in the out position
  • RTO Master
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
6ya staff
SOURCE:
Paslode F16 finish nailer will not return to start position after firing. Need to pull it back.
You may have to disassemble it BUT it may be that the mechanism and sliding parts are dry and stuck with glue from nails etc so may also work to apply a rust solvent to the sliding parts and let it sit and work the nailer a bit etc.
Sep 21, 2014 | Paslode 1-1/4 In. Straight Finish 18 Gauge...
Looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
Jammed
Make sure that you are using the correct angle nails and head type,,,some use clipped head , others full head,,,others offset full head
Feb 09, 2013 | SK Paslode Sk312 Framing Nailer O`ring...
Firing pin keeps jamming everytime i fire the gun everything else seems to be in working order would appreciate some assitance on this matter
check for a jammed nail in the nose area and also check for the nose itself and or the driver blade being bent. Also when was the last time tool was cleaned and serviced, that might have some impact on usage.
Jul 10, 2011 | RTO PasLode 900420 Impulse Framing Nailer
I have a paslode straight finish nailer, purchased in Australia around 2001. The problem is that the pin that drives the nail out of the gun does not retract back into the cylinder. I have it apart and the...
is the cylinder really dirty, if so it needs a thorough cleaning. your instruction mnual detailes how to do this. also look for a jammed nail in the nose area and possibly a bent driver.
Sep 15, 2010 | Omega Paslode 901000 Impulse Cordless...
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Nail comes out another hole
are you using the right nails and are they inserted properly if this is an angle gun? Also look for a jammed nail that might be causing this. look at the magazine bolts to make sure they are tight. You can go to Paslode.com for the owners manual and troubleshooting guide.
Sep 10, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Angle brader firing problem
not real familiar with the gun in question, but when i have that problem with my Senco guns I usually make sure the nose is clean of gunk and spray some WD40 up the nose
Jul 22, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Mar 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
RTO Paslode 902000 IM250 Ii Cordless 16 Gauge 3/4 2 1/2 Inch Straight Finish Nailer Logo
2,526 people viewed this question
Top RTO Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a RTO Tool and Hardware - Other Expert? Answer questions, earn points and help others
