ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
Posted on Dec 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will an Asus m2n-e sli run an AMD Athlon X2 7850 2.8GHz am2+
Azrael SRL
Level 3:
  • ASUS Master 11,800 Answers
  • Posted on Dec 24, 2010
Azrael SRL
ASUS Master
Level 3:
Answers
11800
Questions
0
Helped
2566803
Points
35672
As you can see here
http://www.cpu-upgrade.com/mb-ASUS/M2N-E.html
if you have the correct BIOS, yes.
1 Related Answer
Azrael SRL
  • 11800 Answers
  • Posted on Jul 11, 2010
SOURCE: is an amd athlon x2 compatible with a asus m2n-mx
Yes, perfectly compatible.
Need to upgrade CPU to AMD Athlon X2 7850. Is this possible?
Yes it is possible but confirm that your motherboard will able to support AMD Athlon X2 7850 if it won't then you need to upgrade the Motherboard too.
Keep tuned
1helpful
2helpful
CAN I USE AN ATHLON II X2 245 ON MY M2N-E SLI
No, it's an AM3 processor, it will simply not not be recognized in an AM2 board with an older chipset like yours.
1helpful
2answers
Asus M2N-E SLI
In my experience, there are some fans that are loud. It could be bad bushings or possibly a fan that is out of balance. The Cool and Quiet utility will not solve that problem.
Are you sure it's the CPU fan?
If the computer (or it's parts) are less than a year old, they should be under warranty.
If it's the case fan, I'd replace it with either a new single-speed fan or one that has a variable speed adjustment.
2answers
Bus Speed 200mhz instead 1000mhz
PLEASE INDICATE WHAT IS YOUR PROBLEM....
No video
could be that the drivers are not correct for the monitor/videocard that you have set up. have you tried downloading some newer ones from your monitors manufacturer?
Motherboard Issue
Hi Tomokato,
This maybe nothing but the first thing I checked is the CPU.
Supported CPU list through Asus web site for M2N-SLI
(Click on this link). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=M2N-SLI
The first supported 64 X2 is;
Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2
Second CPU supported;
Athlon 64 X2 3600+ (DD),1MB,65W,rev.G,SocketAM2
The CPU that you are using is not supported.
Since this is a new CPU, you might be able to exchange it for the Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2.
Link to Asus main web site for M2N-SLI.
http://support.asus.com/download/download.aspx?modelname=M2N-SLI&SLanguage=en-us
Suggest you add the above link to you're favorites.
Even you're memory is not supported. As seen in user manual page. 2-13.
Have more questions, feel free to ask.
Mike
2answers
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
