Canon PIXMA IP5200 InkJet Photo Printer Logo
Posted on Dec 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plz hellp me? i have 2 printer ,my first printer canon ip5200 have a error 6500 and other printer(canon ip 4300) have error b200.
polytek
Level 3:
Guru:
  • Canon Master 453 Answers
  • Posted on Dec 24, 2010
polytek
Canon Master
Level 3:
Guru:
Answers
453
Questions
Helped
141176
Points
1722
For your ip4300 you need to change the printhead and for the ip5200 you need to change the logic borad.
3answers
How to Fix Canon Printer Error B200?
Canon Printer Error Code B200 here another common printer trouble you reasonably might have confronted one or several times when while using your printer. I liked to add this since I have read a lot of complaints about this error message. Canon Printer Error B200 usually links to a printhead problem and a failure message of support code B200 will flash on the LCD panel.
4 Easy steps to Fix Canon Printer Error B200:-
1. Switch off the printer. Remain until the cartridge carrier returns on the side.
2. Switch on the printer.
3. Remove the cartridges. Check the nozzles and clean them if there's any clogged or dried ink.
4. Reinstall the cartridges.
Canon Printer Error B200 has heard Canon printer users quite often. But, the good point is that there is a method that you can follow for managing and fixing this error. A reliable guide for troubleshooting can change the user's fix the Error Code B200.
To Fix Canon Printer Error B200, you want to join with Printer Error Support specialists. You can also follow the easy steps to Fix Canon Printer Error B200 are given below in this BLOG or Call us.
I have canon 3600 printer that has b200 error how do I fix?
Printer failures are quite common among users. There can be Canon Printer Error B200 error for 2 or 4+ cartridge. The dreadful Canon b200 error can mean a lot many obstacles that can end up confusing the user in no time.
If you do not fix the Canon printer error b200 perfectly, there can be a want to buy a new printer altogether. To circumvent such expense, choose the problem the moment it arises.
6 Right steps to Resolve Canon Printer Error B200:-
1. Printer Driver-You should not ignore the notification to update the driver of your Printer.
2. Cartridge Related Issues-It may be possible that the reason behind Canon printer error b200 is the cartridge issue.
3. Blocked Nozzles-Blocked nozzles could be the main reason behind Canon error b200.
4. Tank Holder-Maybe you are facing the issue just because of a damaged Tank holder.
5. Check for any Stuck Paper-Open the print head of the printer and check if there is any piece of paper that got stuck inside it.
If the problem continues, check this blog or call Canon Printer support services or a Printer Support to stop more printer damage the number is in this blog- Canon Printer Error B200
Canon e500 series error b200
Canon Printer Error B200 commonly links to a printhead problem and a failure message of support code B200 will flash on the LCD panel.
Steps to Fix Canon Printer Error B200:-
1.Reboot printer. Un-plug your printer and give it cut for at least 30 minutes.
2. Exclude any blocking. There's a chance something is interrupting the joint to your printer head.
3. Cleaned printer head applying your Computer printer maintenance options.
Want To Fix Canon Printer Error B200, you need to join with Printer Error Support specialists. You can also follow the easy steps to Fix Canon Printer Error B200 are given below in this BLOG or Call us.
Canon mx892 shows error code B200: Printer error has occurred. Unplug the power cord and contact the service center
The fault in Canon Printer Error Code B200 indicates a defective print head. A print head is a component that directly collects the ink onto the paper from the cartridges, which means it's one of the most critical parts of the printer.
Canon Printer Error Code B200, which can signify a hugely damaging system error, is one of the most feared.
Want to Correct the B200 Canon Printer Error Code?
1. Unplug and leave your printer disconnected for a minimum of 30 minutes.
2. Open your printer's door and you can move the print head so you can reach it.
3. Take off old ink.
4. The complete Canon Printer Error Code B200 solution.
Check this Blog - Canon Printer Error B200
3helpful
I have a ip43oo and I get service error B200 What is it?
Your Pixma ip 4300 error B200 definition: Over-heated print head. It sounds like an: "ut-oh', but not a big deal. The reason the print head overheats? Ink needs to be replaced... Replace the ink cartridge that is low (you should have received that message at least once).
I would shut it down to prevent damage, until you can get the ink cartridge replaced.
2answers
SERVICE ERROR B200
Canon Printer Error B200 has tried Canon printer users quite frequently. However, the good point is that there is a method that you can follow for managing and repairing this error.
Easy & Simple ways to Resolve Canon Printer Error B200.
1.Re-boot printer. Un-plug your printer and give it cut for at least 30 minutes.
2. Eliminate any blocking. There's a chance something is interrupting the joint to your printer head.
To Resolve Canon Error B200, you want to join with Printer Error Support specialists.
Full Blog - Canon Printer Error B200
Hi I have printer IP 4300 Canon.The error is B200 Can you help me please?? Thanks Nicolas
No worries, here's how to reset the machine:
1) Hold the On/Off button for 1 sec. until the printer shuts off.
2) Unplug the USB cable and then the power cord.
3) Press the power button for 1 sec.
4) Wait 10 minutes, then plug the power cord back in and then the USB cable.
5) Press the power button to turn it on again.
Read more: techbelkin
28helpful
2answers
13helpful
2answers
Getting an error message 6500 on a canon ip5200
my printer found this problem error 6500 my printer model is canon ip 5200 what do i do?
2answers
Error on Canon Pixma IP5200
20 times Other hardware error [6500] - Logic board ***'y (QM2-2670)*1
Its the small circuit board next to the carriage unit
You can get one for about $30 from this company web site.
www.euro-parts.it/download/slowmover_oct-2008.xls
You probably have to contact them directly to get your exact circuit board.
old marine
old marine
ZJ Limited
ZJ Limited
