Question about Panasonic PVQ-M2509 Combo
No sound/audio while playing tv. - Panasonic PVQ-M2509 Combo
    Top Expert:
  • Panasonic Master
  • 76,171 Answers
Hello
If there is no audio output from your tv, either your TVs speaker or its audio output IC has damaged. You just check it with an earphone/headphone, if there is an earphone or headphone socket in front panel of your TV. If there is sound from the headphone/earphone, and not from the speaker, means the speaker has damaged. You have to replace it with same type and number. Just check your set's audio out socket, if any provided, connet it to any external audio sourse, like amplifier or so, and check whether there is sound output from it. If not, your Tv/combos' sound processing IC inside has some trouble.
most common fault is related to sound output IC or speaker itself. If speaker is found OK, go to the sound output section. This section can be easly located as speaker wire goes to that section, and follow it. Before replacing the IC, check its leads for any loose or bad soldering. i advice you to resolder all the terminals of that IC, by applying a little more solder, without making any solder bridge loose contacts between them. If this does not helps, replace the IC with an identical type and number. OK.
Posted on Dec 24, 2010
6ya staff
SOURCE:
What do I need for my vizio TV and JVC receiver to
A standard RCA cable audio out of the tv to audio input of the receiver(ie, tv in or auxillary in (select which input you used on the reciever menu) The sound from the tv will be played through the receiver.
Oct 06, 2014 | Audio Players & Recorders
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Picture ok but no sound from tv when I connect laptop to tv via HDMI. Any help?
Simple fix : Click start and type sound and goto "change sound card settings"-> goto HDMI sound (tv icon) and right click it -> select "Set as default" It will work. Just restart the application from which you are trying to play the audio. It will work 1000%
Dec 03, 2012 | Dell Inspiron 1501 Notebook
I cant get the tv to go through the surround sound i can only get the surround sound to play when its a dvd playing do i need another wire to go from the dvd player or will it not work no matter what plz...
If you've got the Audio Input Source set as TV-Audio and it won't play as Surround Sound then you'll need to connect the Audio Out from your TV (if it has one?) to the Audio AUX IN on your LH-T360SE and change the Audio Input Source to AUX.
Jun 04, 2011 | LG LH-T360SE Theater System
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
No Sound on my rear projection TV...audio plays
Check the audio amplifiers IC of the tv
Aug 11, 2009 | Televison & Video
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
Using TV card on PC video perfect no audio
SOme PVR cards need a small cable from PVR card to the Sound card input to play sound via the sound card.
Jan 16, 2009 | Leadtek WinFast PVR2000 Video Capture
No sound for TV AVR 786
Check cables, see if other audio sources work through audio input ports.
Apr 24, 2008 | Denon AVR-786S Receiver
Sound Problems with HD TV
get the digital audio optical cable and connect the to the tv- got it working tonight
Oct 07, 2007 | Samsung HT-Q100 System
Panasonic PVQ-M2509 Combo Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
