Push Mode, set and on/off button together. It will show your clear sign. That’s it
Tried pressing mode and set together and it didn't work.
Then i pressed the following and it worked.
I pressed and held down each button one button at a time and held all 3 down for a few seconds til it said 'clr' on the screen.
The buttons i pressed were 'set' 'mode' and the 'on/off' button respectively.
Push the mode and set buttons simultaneously to clear the check filter message from the display.
manual is here:http://www.salton.com.au/files/prod_manu...
SOURCE: I have a Russell Hobbs Power Cyclonic Pets 2000W
I have exactly the same problem, has anyone given you advice?
SOURCE: Nikken Air Purifier, Model NKAP100:
Under the front panel, under and to the right of the control panel is two holes, one the size of a pencil eraser and below it is one the size of a dime. In the hole (the size of a dime), is a pin hole use a paperclip and poke the hole. It will reset the filter light. We had the same problem, and couldn't find the manual. Our Nikken rep was No help either.
