Hello, It sounds like you have a defective power supply. Typically, +5 volt stby is present if the TV switches on with front indicator light. On the power supply, connector 802 pin 4 is the on command from the pcb main to switch the p.supply on. If this signal is present but still no VS,VA,VE panel voltages are missing, the p. supply is bad. Good luck!
Bill W.
integrityhomeworx.com
