I don't know if your problem is the same as mine, but I have a Nikon Coolpix still camera, and I suddenly had a similar problem. I contacted Nikon, and they asked me to email them pictures taken with the camera. Then they replied and said I would have to send it in for repair.
I hate to say it, but if your screen and video are red, you probably have an image sensor problem that will have to be repaired. If your problem was only a red screen, it could be a loose connection, but since it's making it all the way to the tape, it's probably bigger. Sorry!
If
the touch screen of the Camcorder is not working, please follow the
troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button above the hand strap.
Note: In the above picture, 10 represent the reset button.
If the issue persists again, please perform LCD screen Calibration and check if
that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please
remove the battery pack, turn the Power switch to ON for more than 15 seconds,
turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps,
service is required.
I hope this information will help you to resolve the touch screen issue of the
Camcorder.
