has no sound at the front panel ? not sure i understand are you getting any sound or you dont have a sound icon
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
hope this helps
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Using
a microphone with computer
To use any microphone with your
computer you will need to enable it in control panel. The following
instructions are for Windows XP but are broadly similar for Vista
and Win7
Click START, CONTROL PANEL, SOUNDS
& AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices
Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure
that there is not a check-mark in the MUTE box against microphone in the list
of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't
checked before closing the window.
Now click the VOLUME button in the
SOUND RECORDING BOX. Here SELECT microphone as an input source for recording
(as opposed to un-checking mute in the playback controls).
NOTE if your microphone
is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES
on the tool-bar and place a check against microphone in the list
entitled 'show the following volume controls' and then click OK. Same
applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume
as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust
slider to suit.
You might put a check mark in the box
to show the volume control on the Task Bar so you can go straight to it to make
adjustments in the future.
