SOURCE: spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
SOURCE: Thermadore gas stove top - left 2 burners won't light
Either the potentiors or the simmer control.
SOURCE: two burners wont ignite
Sounds like the electric sending unit for the right burners is not working. Do you hear the cliking noise on the right side when you turn the knob to LITE? If not then you need to replace the electric sending unit, they are located under the knobs, they are a smal square box that goes on the switch valve rod, they have tow wires on the side, just unplug and lift, and look for greasse or anything that might interrup contact, you might be able to use the same ones, or just replace with new ones....Good Luck
Eddie Rentas
Tupper LAke NY
SOURCE: MAYTAG GAS COOKTOP IGNITER PROBLEM only 2 igniters spark
Hello
Check and make sure that the electric sending units to the side that it's not sparking ( Left side or Right side) are good, you can check that by replacing the one that works with the one that does not. they are located under the knobs on the switch rod, it's very simple, they just sit there with 2 wires, just lift and unplug the wires and replace with the good ones, and if they start clicking when you turn the knobs, then just replace the bad ones with new ones.
Hope this help
Eddie Rentas
Tupper Lake NY
SOURCE: Electric ignition for one burner on counter top ge
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
