I am replacing the cylinder sleeve and compression ring on my Craftsman air compressor model 919165020. Searspartsdirect says that I need two compression rings. Is this right? My compressor only had one...
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919165020/0247/0703000 This is the exploded view that I used.
67 head 65 gasket 64 reed valve plate 63 ring,this one goes under the reed valve plate 62 screw that goes thru the 61 piston 60is a ring that sets on the top of the connecting rod screw the piston with the ring into the top of the connecting rod then take the connecting rod end cap off and cover the studs with some rubber tubing.This will protect the crankshaft when you push connecting rod and piston assembly in to the sleeve that is seated in the block.The ring should be flexible enough to push into the sleeve,if not a bit of oil should help.Guide the connecting rod on to the the crank shaft.I hope this helps and thank you for using FixYa.com
Owner's Manual - CRAFTSMAN Air compressor 919165020, 919165050, 919165090, 919165230, 919167330, 919165221, 919165070, 919165310, 919164200, 919165060, 919165300, 919152922, 919165250, 919186430, 919155613, 919164150, 919165030, 919165130, 919165500, MG2-OILFREE, 919165110, 919167200, 919165000 - ManageMyLife.com
