Question about Kodak EasyShare CX6330 Digital Camera
Formating memory card 4.0 gb on a cx6330 easy share color science kckcl40305475. having problem formating . states card has to be formated shows continue on screen thats as far as i can go.
    Brigadier General:
  • 11,967 Answers
Check your manual to see if you can use a 4GB card.
Posted on Dec 23, 2010
6ya staff
SOURCE:
SD card format ng no card
  • 1 Insert your SanDisk 8GB memory card into a card reader connected to your computer.
  • 2 Double-click "Macintosh HD" on your desktop.
  • 3 Click on the "Applications" folder, then the "Utilities" folder.
    4 Double-click "Disk Utility". Look on the left side to locate the drive that says "SanDisk.
    5 Select the capacity of the drive on the left side of the window. The capacity will state "8GB" or "8,388,608 kilobytes." Click on the "Erase" tab to format the memory card. When you see "SanDisk" listed as the device's name, the capacity will be located above. You need to select the capacity and not the device.
    6 Select the appropriate "Volume Format." Under the "Volume Format" button, select the format you wish to use. Select "Mac OS Extended" if the SanDisk 8GB will only be used on Macs, or "MS-DOS (FAT)" if you will share the card between a Mac and PC. Select "Erase" to complete the format of your SanDisk 8GB memory card.
    Mar 07, 2012 | Panasonic AG-HVX200A Mini DV Camcorder
    Difficulty formatting new memory card for a Kodak Easy Share DX7440
    The DX7440 works with MMC and SD cards, which max out at 2GB. While your 4GB SDHC card fits into the slot, it is electronically incompatible and will not work with this camera. You need to stay with SD cards, 2GB and smaller.
    Dec 01, 2011 | Kodak EasyShare DX7440 Digital Camera
    I have a new memory card for my kodak easyshare cx6330 camera.when I turn the camera on the message on the screen says memory card requires formatting. when I attempt to format it it says formatting for...
    The CX6330 works with MMC and SD cards. If your new memory card is larger than 2GB then it's actually an SDHC card and will not work in the CX6330.
    You can view/download the manual at the manufacturer's web site at
    http://support.en.kodak.com/app/answers/detail/a_id/18498/kw/cx6330
    Jan 04, 2011 | Kodak Cameras
    I tried using a 4GB SDHC card on my Kodak Easyshare CX6330 and it went into a state of perpetual formatting. The card now does not work on any reader i have. Is there a way i can reset the card or manually...
    The CX6330 is designed to work with SD and MMC cards. It will not work with SDHC cards. You need to use SD cards 2GB and smaller.
    You cannot use the card on the camera. If you have a card reader or other device compatible with SDHC cards, you should be able to format the card there.
    Sep 02, 2010 | Kodak EasyShare CX6330 Digital Camera
    Memory card formatting
    Get a separate card reader and use it to download your pics to your computer. Then, format the card in the camera. 6153108.jpg
    Jun 21, 2010 | Kodak EasyShare Z1085 Digital Camera
    How do i format a kodak memory card 4 gb sdhc for my kodak easy share z612
    Unfortunately. you don't. The Z612 works with SD cards, not SDHC cards. You're limited to cards 2GB and smaller.
    Jun 14, 2010 | Kodak EasyShare Z612 Digital Camera
    Cant get my camera to format a memory card
    agreeing with fixer1950. This model is in fact just designed for up to 2GB SD or MMC card.
    When Easyshare one was released, 4gb SDHC was not yet created. You will always get the "memory card requires formatting" (looping until you get a file sys error msg) if you will keep on trying to use the 4gb.
    Aug 12, 2009 | Kodak EasyShare One Digital Camera
    Camera will not format 4 gig card
    I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
    Jun 04, 2009 | Kodak EasyShare Z7590 Digital Camera
    New memory card will not format
    You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
    Larry
    Mar 23, 2009 | Kodak EasyShare V550 Digital Camera
    Kodak EasyShare CX6330 Digital Camera Logo
    66 people viewed this question
    Top Kodak Cameras Experts
    Ekse
    Vitally Alcher
    FIKRET UNALIR
    FIKRET UNALIR
    Level 1 Expert
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
