SOURCE: ACER LCD monitor no image, appears white color only
Quickly go to the Acer website and check FAQ's and while there also find out how to get an RMA to return it. My guess is you have a bad monitor. At $200 roughly for a replacement I would hustle. I am assuming you got nothing but a white screen but did get video on your TV.
SOURCE: Power light Flashes on and off stays blue
Hi...there,
It's seems you got a busted AD Board... your LCD bios had been damaged or erased.
SOURCE: Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
SOURCE: View sonic monitor VA712
It may have blown fuse in the backlight inverter board, that will be the first place to look. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Post pictures if you can.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
SOURCE: My view sonic VA712 monitor
Hello Dear I also have the same problem and finaly I found its power adopter faulty which gives the same voltage as mentioned above it but on load they dropped to 17 volts instead 19. I used another supply and the monitor works normaly.so try this
