Question about Panasonic TC-P42X1 41.6 in. Plasma HDTV
My TC-P42X1 will not turn on, and instead it clicks once, and then the red LED light blinks ten times. I've tried all suggested methods that Panasonic Tech support has to offer yet still nothing works. I'm pretty certain at this point that a repair guy needs to come and look at it to further assess the problem but I'm worried that this is going to cost me a ton of money. I'm hoping not. Any advice or good thoughts?
  • 178 Answers
May defective SD, SU or SC board, please see picture step 1.My TC-P42X1 will not turn - tvhelp_dave.jpg
Posted on Jan 03, 2011
6ya staff
SOURCE:
Panasonic TC-P50X1 don't come on, red light blinks 9 times what is the problem
1) try doing a RESET.
2) if that does not work. with most flat TV today. There three circuit boards - an input, a power and a video. Usually, it is the power supply and specifically, the capacitor(s) that goes wrong. It has high voltage (400 volts) but low current.. Replace this capacitor or could be capacitors.
Oct 26, 2017 | Panasonic Televison & Video
Panasonic tc p50g15 tv will not turn on tried 1 minute unplug reset and 20 sec power button hold in. Did not work now no led lights
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 17, 2016 | Panasonic Televison & Video
How do I safely replace the A-board on a Panasonic TC-42PX24 plasma TV? (Or, how do I confirm that the A-board is truly the problem component?)
May 17, 2016 | Panasonic Tc-42px24 42 in. Plasma TV
Panasonic TC P5G20 turns on but screen will not activate. It then clicks and the led blinks 13 times. I've turned it off and on a few times and once the light blinked 4 times, but it's now...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 16, 2014 | Panasonic Tc-p50g20 Viera G20 Series 50"...
Tv. TC-P42X1X. in protecction.
Might be a problem with bulged capacitors - its one of the most common faults on any electrical item - best take it to an electrical repair shop.
Unusual on a Panasonic television as they are the best you can buy for a reason they used to use the best capacitors and internals.
Apr 11, 2014 | Panasonic TXN/A1EQUUS TNPH0800 Main Board...
The TV dosent star up only flashing power led
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Jan 05, 2014 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
I have a panasonic model number TC-P42X1 and i have no picture or sound. and the red light flashes every 4 seconds none stop
I had a similar problem with my Hisense TV and I replaced the "Main Board". Got the part on ebay. Don't know if this will help.
Jan 02, 2013 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Panasonic TC-42PX14 wont turn on power light flashes 1 time
You may want to shop for that board or at least consider removal of the HDMI socket in question---tested for shorts there I presume?
Nov 05, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Panasonic TC-P42X1 41.6 in. Plasma HDTV Logo
985 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
