Mitsubishi HS-U448 VCR Logo
Posted on Dec 23, 2010
I have a Mitsubishi HSU48. The tape is stuck in the VCR. I cannot get it out. Do you have any suggestions
James Hurst
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 10, 2014
James Hurst
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
690
Points
I had this problem with this specific machine. These answers have all been general to any VCR. The Mitsubishi HS-U448 has its motor underneath the machine. You don't have to remove the top cover at all. Just remove the bottom plate and spin the motor (the correct direction) to completely eject the tape.
5 Related Answers
Anonymous
  • 119 Answers
  • Posted on Jan 24, 2007
SOURCE: Tape stuck in VCR, won't eject.
depending on th einternal design of the vcr. look for the loading/unloading mech, by finding the blak rubber belt that is looped from the motor to a pully. now turn it one way. it may thak 25 to 50 complete rotations of the belt. try turning both ways, one will load & 1 will unlaod. good luck.
Anonymous
  • 579 Answers
  • Posted on Jan 08, 2008
SOURCE: stuck tape in vhs/tv combo
Unplug the TVCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
sharcnet
SHARCNET-USA
  • 2130 Answers
  • Posted on Jan 15, 2008
SOURCE: Toshiba M-752 Video Casette Recorder
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Another possibility is that the tape is caught aroung the spindle guides that pull the tape around the video head. If the tape is caught in the spindles, this will affect playback performance. The heads could be dirty too. Another possibility for poor playback is a slipping idler wheel. The idler wheel is a rubber tire that pivits between the tape sending and pickup reels. It's a key part during playback, fast forward & rewind. The idler tire can also be treated with a re-grip solution or be replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor.
Anonymous
  • 883 Answers
  • Posted on Feb 05, 2008
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
sharcnet
SHARCNET-USA
  • 2130 Answers
  • Posted on Feb 28, 2008
SOURCE: Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
1helpful
How to eject stuck tape
might have to remove bottom of vcr and manually move the drive motor by the belt or the pully. if the bottom doesn't come off, you'll have to remove the top. usually screws on the side bottoms and one in the back. you can reach the motor from there.
1helpful
Will not eject tape
take the top off the VCR, you will see where the tape is hung up. Reach down and release the tape and pick it up, now close the top.
How to Remove a Stuck-Up Tape
Take the top of the VCR off and remove it manually. If you don't do this you risk ruining the tape.
1helpful
I have a Mitsubishi U57 VCR. Works well but have a tape stuck in it. Any suggestions on how to get it out?
Unplug the vcr for 30 seconds, sometimes the tape will eject, failing that ! remove the top cover of the vcr "2 to 6" screws. Now! if the tape is spewed in the mechanical parts and wrapped around the video ahead, get a pair of scissors and carefully cut away the tape and remove any particles, next hit the eject this should remove the cassette without difficulty. If all this fails the problem lies in the vcr itself, a bad idler assembly, broken drive belt, or loading basket problem which will require a technician.
Tape stuck will not eject
open vcr look for a belt on the right side of the vcr and begin manually turning it until the tape ejects
A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
2helpful
A tape is stuck in my VCR. and i cant get it out, How can I remove it? notheng
Open bottom metal cover. Rotate the belts of the motor. Cassete should unload from Spindle and reel back into the cassette. Then please open the VCR top, and you will see a belt and gearmechanism on the right side of the cassette compartment. Manually rotate the gears and the tape will slowly come out.
2helpful
2answers
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
3helpful
Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
