Electrolux Pronto 2-In-1 Stick/Hand Vacuum - Cayenne Logo
Posted on Dec 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery not charging - Electrolux Pronto 2-In-1 Stick/Hand Vacuum - Cayenne
Barrett Palumbo
Level 2:
  • Expert 1,772 Answers
  • Posted on Dec 23, 2010
Barrett Palumbo
Expert
Level 2:
Answers
1772
Questions
0
Helped
502167
Points
289
Sorry to read about your problem, I hope this helps you out.
you batteries are past their recharge life..need to replace
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
1helpful
Hi I have a Dyson handheld vacuum DC35 , when I plug the rechargeable battery in to charge the green light is just flashing and does not seem to hold charge
This means your battery is flat. When charging the battery if the green light on the charger is on then charge is getting to the battery. If the battery isn't holding a charge then you will need to replace the battery.
Irobot roomba 500
If you're sure the battery contacts are clean and the battery really is charged, then there is faulty circuitry within the Roomba that would have to be repaired or replaced.
Confirm that the battery is inserted with the metal contacts down so they make contact with the spring terminals in the battery compartment.
Visually confirm that the metal contact plates on the battery pack, and the spring terminals in the battery compartment are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
Visually confirm that the metal contact plates on the Roomba, and the spring terminals on the docking station's home plate are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
If you have a volmeter, measure the voltage between the contacts on the battery pack If it isn't something in the neighborhood of 14 volts and is 11 volts or less, the battery isn't fully charged.
Reinstall the battery.
For the moment, please connect the power adapter directly to the Roomba rather than the docking station to eliminate one possible faultly connection.
If the battery wasn't fully charged, or you weren't able to test it, try to charge the Roomba and then retest the battery voltage if you can. If the battery voltage was higher immediately after charging, but didn't get to 14 volts, the charger is good, but battery needs to be replaced. If the battery voltage was unchanged after attempting to charge the Roomba, the charging circuitry may be faulty. If there was no light patterns when you tried to charge it, and it was plugged in to a good outlet, then the power adapter or charging circuitry is definitely bad.
If you have no voltmeter and you cleaned the contacts and tried to charge the Roomba and it works, use the Roomba and then recharge using the docking station and see if it was just dirty contacts or it won't charge through the docking station. If it didn't work, you'll need to figure out if its the battery, the charging circuitry in the Roomba, or the power adapter. If there are no lights when you try to charge the Roomba, then Either the power adapter or the Roomba power circuitry is defective, but without a voltmeter you can't find out which one, and there's no way to know if the battery is good or bad, but you know Roomba wasn't trying to charge it. If there are lights when you try to charge the Roomba, then at least you know the power adapter is good. Unfortunately, without being able to test something there's no way to distinguish between a charger that won't deliver a charge to the battery and a battery that won't accept a charge. If you want to take a guess then a bad battery is more common and less expensive to fix.
I have an Energizer Model CHDC7 battery charger for AA/AAA batteries. I'm not sure how to use it. Specifically, when batteries are inserted and plugged in, it displays flashing green lights over all...
Nickel-Metal Hydride (NiMH) batteries are usually charged in pairs in consumer chargers. The CHDC7 can charge two or four batteries at a time. Their position in the charger is important (see the link at the end of this note). Each battery has a separate pair of green LEDs. There are no other LEDs on this charger. The LEDs light up to show the state of charge. Flashing means it is charging. Solid means it has reached that level of charge (ie, 1 LED = half charged, 2 LEDs = fully charged). The batteries will get warm but not uncomfortably so. After some practice you will be able to tell if they are getting too hot (which may signal a worn-out battery which should then be replaced). Like all rechargeable batteries, NiMH batteries have a finite life (measured in number of times they've been discharged and recharged). IMHO, they should also be used and charged in matched pairs. I mark them when I take them out of the box and keep them paired in use and in charging for maximum life. Yes, the devices that use 3 batteries are a pain to deal with. LOL. All details can be found on this Energiser data sheet: http://data.energizer.com/PDFs/chdc7_instructions_english.pdf
P.S. The CHDC7 remains open for charging. Closing it for storage is optional but minimizes the space it takes up.
Jul 30, 2011 • Vacuums
Will not hold charge. do i need to buy new battery?
Hi make sure the unit is charging by checking it with a tester , i am not sure of the voiltage when charging but if you look on the charger it will have the amount it should be charging the battery, if it is charging and your battery is not taking the charge then replace the battery
1helpful
How long i have to charge my Euro-Pro Shark
mcdevito75 here, I believe a full charge would be 4--6 hours, but wait until battery needs the charge, to charge a battery with an already half charge or better could shorten battery life.
1helpful
2answers
My roomba was not used for a month. Now it does
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
3helpful
2answers
Cordless vac won't hold a charge
Like all batteries after a while they go bad/will not hold a charge. especially the kind that is always plugged in/always charging, like electric shavers, cordless vac and so on.
get a new battery
thanks for rating
Jan 14, 2008 • Vacuums
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
