SOURCE: Soap suds on the door at the end of a wash cycle. Miele E526
With all modern front loading washers, you might find that the amount of detergent you need is much less than what is recommended by the detergent makers!
First, be sure you're using the He (High Efficiency) detergent and try using only 2 or 3 tablespoons of detergent. If you've heavily stained clothes, be sure to pre-treat them rather than adding more detergent. That should also help with the extra soap left in the clothes after a complete wash cycle.
Give this a try and adjust the detergent as needed to get the best results for your situation.
Hope you find this Very Helpful and best regard!
SOURCE: leaks from front door 2 loads AFTER too much suds
No. It is not a costly affair. Order a new door boot seal from your local agent and fit it yourself. If you lift the outer lip of the seal on the front of the machine you will see a wire that runs all the way around the seal and attatches to a spring. Remove this wire and pull the seal free. On the other side you will find a strap holding the back of the seal in place. Loosen the strap and the seal comes away. Fit the new seal in reverse order ensuring that the drain hole/s are at the bottom of the seal.
SOURCE: Suds leaking from back of washer near top
I have the same problem now and again on my front loading LG. I
noticed that it is coming out of a vent on the tub right where you
metioned that is part of the design. Either there is too much
detergent or the drain is restricted. When there are lots of suds
they have to go somewhere. It's either out the drain or out the
vent.
But seriously, take it out back and shoot it at you're earliest
convenience and steer clear of LG appliances in the future. Good
luck!
SOURCE: leaky washing machine
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
SOURCE: sud error message
Hello, The most common cause of the 'sud' alarm is too much detergent, or the detergent that is being used is creating too much suds. It works and alarms off of the motor current draw. The causes and cures listed below are pretty much in order of their commonality; try the first item before the second one, etc. If you can pin the fault on the detergent, try using the least amount of detergent that you can while still getting your clothes clean. With a HE washer, more isn't always better. Read on:
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked
• Check / Clean Drain Pump Filter of foreign objects
• Check Drain Pump
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check the Pressure Switch
• Check CCU
Replace failed component.
Hope that this helps. Try the empty loads first to clear the detergent. This is the easiest fix.
Best regards, --W/D--
