SOURCE: My electronic ignition on gas Wolf cooktop(30
Is the ignition battery or mains electric? If it's battery,check the battery isn't flat. If it isn't it will be the ignition unit.
If it's mains electric it's more than likely going to be the electronic ignition unit.It is quite a fiddly job to change/test this. I would highly recommend getting a qualified 'Gas Safe' engineer to check it out.
I hope this helps.
SOURCE: 30" wolf induction cooktop and it is locked in showroom mode
Hiya, hold the child lock button for 3 seconds. should unlock. Best of luck
SOURCE: Wolf cooktop 5HR light keeps turning on. Pressing
Turn off power to the cooktop (i.e., using circuit breaker if needed) for 15-20 minutes. Once turned power back on, problem disappeared for me. The semiconductor needed to be reset
SOURCE: Wolf Induction cooktop is locked in Showroom mode
If Shr (5hr) appears on the display then the cooktop is in showroom mode. To exit showroom mode the cooktop must be locked by pressing and holding the key symbol for 5 seconds. After the cooktop is locked, press and hold the melt touch pad for 5 seconds.
SOURCE: 36" Wolf induction cooktop cannot get past show
Hello John..... Call the store and ask them what code is needed for this model. They put it in showroom mode and they should have taken it out of showroom mode before it left the store. Shame on them. Joe
THanks for choosing Fixya!
