GE Profile JGS968 Gas Kitchen Range Logo
Posted on Dec 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just installed new control panel on my GE profile JGS968. Probe and Bake lights alternatly flashing. When I try to use the oven, after setting temp the probe light comes on and the panel beeps. It won't let the oven start. Again, this is a brand new, just out of the box from GE, control panel. Thanks!!!
Anonymous
Level 3:
  • Master 2,299 Answers
  • Posted on Dec 22, 2010
Anonymous
Master
Level 3:
Answers
2299
Questions
7
Helped
689470
Points
6523
Normally the bake/probe flashing happens when you plug in the probe. If you don't have the probe plugged in, then double check that your wiring connectors are plugged in properly on your new board or that the wires to the probe connector are not shorted. Make sure that the probe is plugged in all the way. Unscrew the retaining nut, then unscrew the two sheet metal screws holding the housing in place, then give the probe connection a gentle tug to ensure that it is still properly connected.
7helpful
2answers
9helpful
Bake does not work but broiler does.
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
The reason that the temp display reverts to 100 degrees is because that is the lowest default temp setting for the display and until the oven temp actually starts to increase, it won't change. So the temp display is working correctly for the BAKE function.
Here's a line drawing showing the part you may need. Ignitor Part # WB13T10045. The good news is that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one. These aren't cheap at $91 bucks, but you can shop around the web for a better price if you determine you need one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGS905SEK1SS&productCategoryId=0124250&brandId=3272&modelName=GAS-RANGE&diagramPageId=00001&componentDescription=GAS%20&%20BURNER%20PARTS&documentId=G6090295&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you out and remember to disconnect the oven from the electric power before performing any repair work. Best regards!
5helpful
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
1helpful
Most likely a bad bake igniter wb13t10045 cant guaruntee thats the problem but I'd start there.
GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
1helpful
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
3answers
Re.probe and bake
I had the same problem and pulled off the contorl panel and removed the ribbion looking thing. You might have to do this a few times and wiggle it a little. It took me about 4 trys to get it to stop. also you can lock the control panel and the beeping will stop...this was my temp fix until I figured out how to get the control panel off and what to do.
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
