Http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=1104 try the windows vista driver. i found most windows vista driver also work with windows 7. (please rate me if this helps)
It doesn't look like the support Windows 7 yet.... here is there driver page. http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=1104
You can send them a email and ask them, but when there not listed that normally means they don't have them yet.
Sorry
SOURCE: I Want Display Driver of this Motherboard (MSI
You can download the drivers from MSI WEB support site, select your model motherboard to download :-
http://www.msi.com/index.php?func=downloadindex
SOURCE: SERACHING DRIVERS FOR MSI K9MM-V
The motherboard you mentioned has VIA K8M800 and VT8237R Plus chipset. Unfortunately there are no qualified drivers for windows 7 for this motherboard. I suggest you to try the generic windows 7 drivers. In case of a problem download the windows XP drivers from this official link and if the problem is still existing try before the installation to right click on the file you are about to install and check at the compatibility tab the compatibility with windows XP sp3 check-box.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
SOURCE: Need please the drivers of video for the mainboard
There are no drivers listed for Windows 7, You might try the Vista drivers.
Click the link
http://www.msi.com/product/mb/K9MM-V.html#/?div=Driver
