SOURCE: error code 2000-0147
Found this for you hope it helps. See it here,
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=14B3819735D6B40EE0401E0A55177ED2&doclang
SOURCE: My dell inspiron 1545 shuts down by itself, dell
I have the exact same problem. However I don't think the problem is
the oper. system. The computer shuts down at random; many times it
won't even boot. I originally thought maybe their was a loose ram
stick, so i tried replacing it and had no luck. Then I tried removing
the hdd and tried to get into the BIOS, but it still sometimes would
shut off; meaning that the o/s can't be the problem.
It still works sometimes, but other times just shuts off or
won't make it past the initial boot screen. I'm thinking it has to be
a problem with something in the power supply. It's seems like the
power just completely cuts off, i've never seen anything like it.
SOURCE: blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
SOURCE: laptop dell inspiron 1545 no power up
Hello anourkhader
When was the last time you used it, and were there any problems? To find the solution to this problem is a matter of elimination. You should check the following:
Step 1 - Power
- Try an alternative power adapter
- Try plugging in your laptop to an alternative power supply
WARNING - BEFORE PROCEEDING, PLEASE FOLLOW THE FOLLOWING SAFETY PRECAUTIONS!
1. REMOVE THE POWER ADAPTER FROM YOUR LAPTOP
2. REMOVE ALL PERIPHERALS
3. WEAR A WRIST-GROUNDING STRAP, AND CONNECT IT TO AN UNPAINTED, METAL SURFACE. IF ONE IS NOT AVAILABLE, TOUCH AN UNPAINTED METAL SURFACE TO DISCHARGE ANY STATIC FROM YOUR BODY
Step 2 - Remove and reset basic hardware items
Remove and reseat the items mentioned below in the order they're mentioned:
- AC adapter
- Battery
- Memory
- Hard drive
For instructions on how to do this, please refer to your user manual. If you no longer have it, you can download it from here: http://support.dell.com/support/edocs/systems/ins1545/
If after following the above instructions, your laptop still doesn't turn on, I would recommend that you contact Dell customer support, which you can do by following this link: http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
I hope this helps. Please feel free to contact me if you require further assistance.
ajblaj
SOURCE: My Dell Inspiron 1545 freezes just after windows s...
This looks like a hard drive failure. Just to be sure, please go through the link below for running and interpreting error codes from Dell. Good Luck.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
www.techtake.net
