SOURCE: Replacement of bottom oven element for Whirlpool oven
its only screwed in to back wall no???if screws rusted well then drill htem out.hidden bake elemnet??hidden under oven cavity??in that case right side wall of unit comes off( a few screws down back side of panel and it removes from the side.(shut power first this element is always live!!!!!!!
SOURCE: Electrican Question - For a School Paper Not a Real Scenario
In my opinion turning on circuit breaker first is ok. First to determine what is tripping the breaker. Isolate what is on that circuit. There are always different ways of troubleshooting.
SOURCE: Hampton Bay 52" Classic Collection Almeida 52101916
Electricians can be so much fun can't they ? LOL I would ask the electrician to bypass the remote to check the fan operation first. You need to know if your problem is the remote or the fan itself.. A simple wiring change in the junction box can be done to determine which issue to focus on.. Hope this helps..
SOURCE: Need electrical information for electrician to install new power
THE NEC NOW REQUIRES YOU TO INSTALL A 4 PRONG PLUG 10-4-WG WIRE CONNECTED TO A 30 AMP DOUBLE POLE BREAKER THE PIG TAIL ON THE NEW STOVE MUST MATCH THE PLUG SO THE ONE OFF OF THE OLD STOVE WILL NOT WORK GET THE 4 PRONG PLUG AS WELL THE WALL PLUG WILL BE EITHER A FLUSH MOUNT OR A SURFACE MOUNT AS TO SAY IN THE WALL OR ON THE BASEBOARD SURFACE REPLACE WITH THE SAME AS YOU HAD BEFORE IT IS LESS TROUBLE IN THE LONG RUN THIS SHOULD ANSWER ALL THE QUESTIONS THE ELECTRICIAN NEEDS TO KNOW IF NOT LET ME KNOW
SOURCE: Compressor not wired, no schematic or instruction in manual
There is a schematic under the cover of the elecrtrical connection box. Remove the top of the box ( typically one nut on top of the pressure regulator) and look under the cover you removed.
Good Luck
