RCA F25261 25" TV Logo
Posted on Dec 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, Can you hook up a dvd player to this model
Anonymous
Level 3:
President:
  • Master 2,992 Answers
  • Posted on Dec 21, 2010
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1092726
Points
9665
This model does not have an AV input, just an antenna connector on the back. So you can't hook a DVD player directly to the set. You can, however, use an RF converter. The converter takes the audio and video outputs of the DVD player and converts them to an output on TV channel 3 or 4 which the set can tune in. It's not as sharp a picture or sound as hooking up directly, but it's the only option on your TV. You can find RF converters at large retailers (Best Buy, Radio Shack, Wal-Mart, etc.) and many online stores. They run around $20.
3answers
How to hook up a sony dvd player to a emerson tv
Need to know the model numbers of the DVD player and the TV before any sort of help can be given.
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
How can I hook up a nintendo wii through my
Hi, There should be an av button.
do you not have spare connections on your tv?
This is your best way, unless you want to record what you are playing.
Which model do you have?
I will try and help
Regards - Anthony
I need to know how to hook this DVD player up to my RCA-HD52W59
take your dvd player to either a radio shack store or a walmart electronics department. They will show you how to hook up the two items and will even sell you the necessary wires to do so
Connecting DVD Player to TV
If the TV doesn't have video/audio input jacks (I don't think this model does) and the DVD player has only video/audio outputs and no RF (channel 3 or 4) output, then you will need an RF converter. They're only about $15 or so. They need to be plugged into an electric outlet, so you may want to get a surge protected outlet strip (if you don't already have one) to plug everything into. Then just hook up the DVD's A/V outputs to the converter and tell Mom to put the TV on channel 3 and make some popcorn.
2answers
How to hook up a dvd player to a dtv
Hi, If the DTV does not have Video IN, then you can't. Thanks, Mike
Need instrutions for this model.
Please hook your dvd player and tv as follows...
Find Yellow color pin as Video Out, Red and White pins for Audio Out (right and left channels) and same goes to rear input-1 or input-2 what ever is available in your TV. watch out color of pins, same color in both units should be hooked up.
Now play dvd player and select input in tv and enjoy.
Still needs help, please mention model and brand of DVD Player and TV to guide you in better way.
My picture is green. I think the lcd screen is bad. Can I get a replacement part for it and where? Audiovox DVD player model D1708
let me know do you get green picture only with dvd player? and what input you use to hook up dvd player with tv?
Based on your reply, will be able to help you.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
