Try this. It worked for me a few times:
1. Plug it directly into the wall, rather than into a UPS
2. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
3. Wait 30 seconds.
4. Plug in the power cable to All-in-One and also to wall outlet.
5. Check for the functionality.
If you still had the error message, reset the printer to factory default settings:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One
Try this.. this link should help
http://fix-your-printer.blogspot.com/2011/02/error-0x61011beb-on-hp-officejet-and.html
