Belkin (F5D5231-4) Router Logo
Posted on Dec 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have belkin router connected but my computer says it does not have internet connection
JDTec
Level 3:
  • Belkin Master 4,338 Answers
  • Posted on Dec 20, 2010
JDTec
Belkin Master
Level 3:
Answers
4338
Questions
0
Helped
2128035
Points
14653
Reset the router:
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
After you reset the router, restart your computer
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
3helpful
2answers
My belkin basic router is not working
well you can fix such kind of problems via contacting to belkin tech support. for more help you may visit: Belkin Tech Support Helpline
2helpful
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
2helpful
I just bought a Belkin Router Model # F5D8236-4. I have everything wired correctly, but the wireless light does not come on. I can't get the internet to come on to the computer I want to connect to? What...
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network.
First, connect to Belkin's wireless network that you can scan.
After you connect, try to go online
It ll work...
Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
3helpful
2answers
Belkin F5D8236-4 Wireless Router will not connect to pannaway dsl modem with same settings as router I am replacing. Dynamic IP address setup. Modem light continously blinks orange. No internet light.
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
19helpful
Can I install my belkin router without setup cd?
you may install the belkin router by following the instructions given below.
1. Connect your modem to the internet port of the router.
2. Connect your router to the computer.
3. now reboot the modem and computer.
4. open the router setup page, and click on detect the internet connection.
5. now follow the instructions to install the belkin router. for more information you may follow the instructions given below.
How To Setup Belkin Router Install Belkin Wireless Router Fixotip
3helpful
Belkin wireless
the red light means u havent got a connection if u have installed properly try upgrading the firmware the problem might be the routers
http://www.belkin.com/support/product/?lid=en&pid=F5D9230-4&scid=221
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
