READ MANUAL IT CAME IT MAY HELP YOU ADJUST TRUSS BAR.
I believe that guitar has the adjustment inside the sound hole toward the neck - it should take an allen wrench to adjust it - or it could be on the peg head between the tuners - anyway, to check the adjustment fret the first fret and the fourteenth fret and look at the distance between the string and the seventh fret - you want about a 32nd of an inch, called relief, so the neck is not straight, but has a slight bow in it - if you turn it clockwise you will reduce this distance - if you turn counter clockwise you will increase this distance - turn a little at a time - if you are not seeing a change stop and take it to a shop to be checked out - don't turn more then one turn if you are not seeing a change - hope this helps - have a nice day :O)
ON ACCOUSTIS GUITARS OFTEN TIMES THE TRUSS BAR IS UNDERNEATH THE SOUND HOLE ON ELECTRIC GUITARS YOU CAN ALMOST BET THE TRUSS BAR IS GOING TO BE AT THE TOP OF THE NECK. UNDERNEATH A WHITE PANEL.. REMOVE THIS PANEL, UNDO THE 2 SCREWS HAVE A LOOK AT THE TRUSS BAR, SEE HOW ITS GOING INTO THE NECK. WE SEE NOW THAT THE TRUSS BAR HAS A GRADUAL INLET HOLE, GET A SCREWDRIVER IN THERE TO ADJUST IT.
