The drivers for Wndows 7 most likely will not work on Windows XP. If this laptop came installed with Windows 7 it may not have Windows XP drivers. Before you install Windows XP check the LG WEB site for Windows XP drivers for your model laptop. If there isn't any XP drivers then I suggest you stick with Windows 7.
Incompatible types and version of printer drivers when installed in Windows 7 can cause issues which might hinder the installation process thereby causing the installed drivers to become corrupt. The users of Windows 7 are therefore advised to verify the version and type of printer drivers before the installation and install only those drivers that are fully compatible with the Windows OS on the system to avoid these kinds of issues.
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
You need to install the drivers, windows does not recognize these additional buttons until the proper drivers are loaded. Depending on manufacturer windows 7 drivers may or may not be available. Microsoft did something smart with windows 7 by allowing you to use windows vista drivers in windows 7. So if there are no win 7 drivers just download and install the vista drivers. Good luck!
You use windows 7 but you must be need all hard ware support driver,windows 7 need 64 bit support driver.You upgrade your display driver from www.mercury .support.com
HP doesn't have the drivers available for windows 7 cause its only in Beta and they won't have it until windows 7 becomes official and available in stores.
The only chance would be if you go into the control panel and then add printers. See if in there it has your make and model of your printer. If it doesn't then try a printer that is similar and it might install it.
If you still can't get it to install then you'll have to wait for HP to come out with a driver for windows 7.
