Altec Lansing VS2121 Computer Speakers Logo
Posted on Dec 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do you need a driver instaled to use these - Altec Lansing VS2121 Computer Speakers
Brian Sullivan
Level 3:
  • Master 27,725 Answers
  • Posted on Dec 20, 2010
Brian Sullivan
Master
Level 3:
Answers
27725
Questions
Helped
5669721
Points
79191
Yes you need sound drivers
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list
2helpful
We have Mustek Paragon 1200 SP flatbed scanner . We have driver for windows 98 . Now we need driver for Windows XP.
window 98 driver will work with windows xp. install the driver file right click and click install. using the setup file. or go to the windows devices. double click on the scanner in menu go to up date driver. in next box use the install driver from local file and make the file to the drivers you have it will install the files it needs. may say are you sure you want to install the driver as it has no certificate click yes., driver installed now.
I need driver for omega c 11 pc camera
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Hardware driver not detected
hello gfmmon, maybe u not yet installed the motherboard driver.
the solution is install your motherboard driver to your computer: 1. insert motherboard CD to CD/DVD drive 2. open device manager (u can find it at control center or type devmgmt.msc on Run command) 3. in device manager window, you will see mark (it can be question mark or exclamation mark). 4. for every mark u need to update the driver. choose one of them, right click and choose update driver. follow the step then your driver will automatically installed. 5. use the step for every mark until all driver installed. if there is still some mark in device manager window then u need to install the driver manually. so u need to browse your motherboard CD (sometimes Audio driver and Chipset driver need to install manually)
NB: if your motherboard CD have autorun feature then it will more easy to install the driver. Click the autorun then follow the step..
hope this useful, regards.
Need to run diagnostic for drivers. had new hard drive installed, dvd not functioning, nor am able to communicate between pc and projector. was told it was driver issue and needed to re-install drivers....
There is no diagnostic that will tell you which drivers to install. But there is a specific order they should be installed:
Notebook System Software Chipset Utility Video Driver Audio Driver Network Driver Wireless Driver Touchpad Driver Quickset Utility
then you have applications you need to install
DVD Player (PowerDVD) Burning Software (Roxio/Sonic) Microsoft Office or other admin software antivirus
drivers can be found at support.dell.com
Applications, you should have the CDs to install them
2answers
Labtec webcam not working why i did every thing my computer not detecting this ****** i install all the posible drivers already i used window xp. I hate this man.
ok, uninstall all related drivers to this camera,
Now using the supplied disk install the camera software but please do not connect the camera YET, if the camera is already connected,
remove the camera and reboot,
so you installed the camera software now plug the usb camera in, it will now detect the install camera software and work.
Regards
gewiz.
Need to install printer and can not locate install disk
Go to the website of the printer manufacturer. Click on DRIVER DOWNLOADS. Download the correct driver for the printer you want to install. Save the driver on your computer's desktop. In the Windows® control panel, click on the install drivers icon. Drag the downloaded driver into the HAVE DISK data field. Follow the instructions for installing a driver in Windows®.
There is no sound drivers are installed and all text is shaded
Hi
This is the software issue. Need to install the appropriate software to reslove this issue.
1.Ethernet controler - Need to install the chipset driver and the Lan driver
2.Pci bus device - Chipset driver
3. sm bus controller - After installation of the Chipset driver - Right click on the sm bus controller and update the driver - select install from specific location - i will chose the location- Select the model and hardware type as thermal sensor
next - follow the instruction.
4. video controller - Need to install the VGA or Display driver
5. video controller (vga compatiable) - Need to install the VGA or Display driver
With regards
[email protected]
I can't install my driver
all the latest motherboards needs to install the UAA driver first, you might have not installed the UAA driver first you need to install this UAA driver and then try to install the audio driver ...
if you tell me your exact motherboard model i can assist specifically regarding your motherboard ...
but if you have not installed the UAA driver then install and try to install the audio driver you will not get any errors after that like previously ...
regards
-Dileep
2answers
Change from vista to xp
you wont have any probs to install xp but before u go ahead take note of drivers u may need because you will need to install certain drivers after installation.
if you have wireless all you really need at hand is your wireless drivers so as once xp installed install wireless then get online to install any other drivers you may need.
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
 Grubhead
Grubhead
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
