Hello, we are experiencing wlan problems with MC9090 scanners together with WPA-PSK encryption. We are also using MC3070, but with that we don't see any problems. The problem looks like followings, the scanner shows very often, that is can not see any WLAN signal. The Message is "Out of Range". We have more then enough AP. That shouldnt be the problem. As mentioned in the same situation the MC3070 scanner works without any problems. Does someone experienced similar problems?Thanks
Same issue. Old units were Symbol Palm 1846, WEP encryption. No delay between scans, no connection problems. MC9090G, TKIP, on VLAN. Frequent 'Network Out of Range' errors, does not connect in all areas as Palms did, and there is a delay between scans. Not sure if this is a problem with access point, the switch, or the gun itself. SD
We have the same problem. We have 5 AP and 16 MC9090 and i have no communication between the Access points and the RF Guns. I keep getting Out Of Range message. i can ping all the access points but sometimes i can only connect to one AP. Please help. thank You.
