Question about Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit
Air ware xm2go
My xm is 2 years old the word antenna show up on any antenna I hook too home,car or the built in antenna.
  • Mike Schultz
    Mike Schultz Jul 27, 2008
    When I plug in either antenna in the home or car docking station it will not work. Ut just says antenna. If I don't plug in and lay receiver next to antenna it will fade in and out without being plugged in.
  • hartwickjj Aug 13, 2008
    I first had a Roady XT and the Antenna warning started coming up no matter what i did, assumed it was wore out. Replaced the XT with an AirWave XMGo and have used it for over a year. Now it also is suddenly giving me the Antenna message whenever plugged into my car dock. The home dock still works fine. I tried two other (old) car antennas that i have laying around and cannot get the car dock to work. I think they just wear out but any suggestions or ideas are greatly appreciated!
I also had the same problem. After carefully checking the vehicle docking station I observed the "male part" where the antenna wire is plugged into to be missing and some how it had broken off. The replacement for the vehicle docking station is about $45.00 from Pioneer. Way cheaper than getting a new radio.
Posted on Oct 27, 2008
The unit has an internal antenna (that is really poor) that is activated when you unplug the external antenna. This is why you get some signal when you unplug the unit.
I assume the problem is the antenna itself.
My suggesion is that you charge up the unit, take it to a place that sells XM equipment AND has a demo unit working. Be sure to take your docking station with you (it has the plug in for an external antenna). Ask the sales rep to please connect your unit to an external antenna to test your unit as you are trying to determine if your antenna is bad. If it works, you need a new antenna (cable may be cut on the inside or antenna may have water/weather damage). If it does not, then there is an electrical issue inside the unit and the unit itelf will need replacement/repair.
Posted on Oct 17, 2008
6ya staff
SOURCE:
No sound
did you check wires from the xm antenna to the receiver???//
Jan 22, 2014 | XM Radio (XMP6000)
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
XM Receiver: When hooked up to the home kit it will show antenna and will not pick up a signal. When hooked into the car jack it works ok. I replaced the receiver mount about 3 weeks ago and it worked ok...
Hi Kldeaton,
If you can do it, try your car mount in the house, as long as you can supply power via the car plug (12-volts DC). If it does the same thing as the home kit, then you more than likely have an intermittent antenna connection on your home antenna.
Also, check the location of your antenna vs any obstructions, such as trees. You may have the reception worked out so that you have signal from the antenna, but it is "breaking up" from a connector or cable short or open condition. Check the coax for any chaffing also. Let me know if you need more help. Thanks.
Regards, Bill
Sep 28, 2010 | Delphi Roady XT XM Radio Receiver
I would like to connect my antenna directly to my XM2GO unit without the docking station. Where can I find an adapter?
Simple. Go to http://xmfanstore.com , click on "Antennas and Extensions" under "Shop Categories" on the left most side of the site; there you will find "XMFanStore XM2go Direct Connect Antenna Adapter" .
It plugs into the SIDE antenna port of your XM unit and you plug the antenna into that.
This URL MAY be a shortcut:
http://store.xmfanstore.com/directconnect.html
May 27, 2010 | Pioneer AirWave XM2Go Satellite Radio...
No reception
your antenna connection inside the unit is broken on the circuit board,i had one of these and repaired it numerous times by taking the unit apart and resoldering the connection at the board,also their antennas don't last long as far as the antenna plug end is concerned
Apr 30, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My delphi myfi xm2go will not recharge. What do I
New battery - make sure it's WHITE and not a black one as the black ones were recalled.
Nov 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Pioneer inno will not recive xm singal
Are you still having this problem? Sounds like you just aren't getting a good signal. Antenna is not properly mounted, not getting good singal.
Or, the antenna and/or cable is damaged.
Apr 02, 2009 | Pioneer XM2go Inno Satellite Radio...
No reception as a portable unit
My experience with the XM2Go is that it never really works well on the portable antenna -- in my case not a complete failure, but that might be because I am in an urban area there are ground transmitters in addition to satellite reception. But any movement disrupts the signal Here's the solution - record some music on myxm (up to 5 hours) while docked, and play that music when not docked to an antenna.
Feb 17, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Static sound or no sound with FM Trans and with Audio Plug
I agree with you. It sounds like an internal audio circuit problem, especially if the tape adapter does the same thing. Have you tries headphones on the unit? If they work, then get the sure connect as it plugs into the headphone jack (Aux out jack)
By the way, you as an XM customer for years, usually XM will just give you another unit to keep you as a customer. I've seen it many times. Couldn't hurt to ask!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 23, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi xm2go internal antenna
Don't use the wearable antenna - reputed to not work well - was not a good design idea - I don't think any of the other receivers have this feature if that tells you anything. Record music you like on the myXM feature, and play that when you would otherwise want to receive on the antenna. If you are listening to live news, etc, there may be no good solution. (I have read there is an antenna headset, but don't know much about it, but some reports that it works.)
Jul 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit Logo
285 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
