Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
(if both drives on the same cable):
Your boot drive goes at the end of the primary data cable.
Your second drive goes on the middle connection of the same cable.
The red stripe on the data cable needs to be closest to the power connection (red stripe to pin 1).
The jumper on the boot drive set to master.
The jumper on the second drive set to slave.
Look in the BIOS to make sure it sees both harddrives.
Boot the system.. it will need to be partitioned and formatted if not already..
Regards..
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
