well... have a volt meter?
Are the bake and broil coils the same?
If so, you can swap them to see if the broiler element glows in the bake position... if so then the element is NFG... to proove that put the bake element in the broil position and fire up the briol function... it should not heat up...
Usually the MFG. intentionally makes the elements with a different offset, so you cannot mix them up...
that's what the meter is for... unplug the element, and put the probes in the socket.
You will be reading 220 Volts, so be XTRA careful... if no 220 then the Module that controls the relay to activate the element connector is not working correctly... so you have to sorts test both ways...
Just be careful...
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/lisa_52daba487e5b4d53
