A couple of things, is this new or old..
1. you should have hooked up to hot water side of water not cold
2. you should have summer/winter bypass installed
3. what is your outside humidly running.
Pleas rate this response with thumps up section thanks..
New -one week old. I am hoping that it just needs time.
I just bough a humidistat to tell me what it is in the house. It now reads 40%, But the control on the unit triggers at 20%, and I am still waking up with a dry nose and throat.
Damper installed and open
I have an on demand hot water heater and the flow rate of the HE will not trigger it. However, they say either is fine.
Outside is around 5% to 10% max (Ohio winter).
All doors and windows sealed holes.
yes it takes, takes a while,,40% is alot if outside is 5 to 10..if you can have hooked up to the hot water line, at least it will get hot water some of the time. for the house to adsorb the moisture
