Viking 31 in. VGSU101 Gas Cooktop Logo
Posted on Dec 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn on the burners they make a clicking sound for several minutes. First it was only the back burners now it is all of them. How do i get them to stop clicking!
Barrett Palumbo
Level 2:
  • Expert 1,772 Answers
  • Posted on Dec 21, 2010
Barrett Palumbo
Expert
Level 2:
Answers
1772
Questions
0
Helped
501860
Points
289
Sorry to read about your problem, I hope this helps you out.
you may have a defective gas control or a clog in the gas feeds
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Two burners on thermador cook top turn off by themselves
It is common for electric coils on a range top to click/on/off. They are suppose to reach a certain heating range and when satisfied, they go neutral and when the demand for heat is needed, they become energized again.
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Hello. When I turn on a burner, another one
they will all click when lighting,
if this is happening after ignition, turn your flame just a bit higher, your loosing flame ground
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Wrong ignitor starts when burner is turned on.
Sounds like you have a bad ignitor on that burner.
30helpful
9answers
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
21helpful
3answers
Dacor gas range igniter clicking
I did have the same problem after the house keeping people done with cleaning. They used window/surface cleaner. First I asked them not to clean the ignitor with any cleaner. Here is what I did to solve the problem
I took scotch scour pad (one that you use for washing dishes), In dry state I polished ignitor switch. It is abrading the residuals and deposits on the top and polishing it. Don't use any thing more abrasive than that. MAGIC - I don't have any more problem.
5helpful
2answers
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Top Viking Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
