I have a lightweight comforter stuck between the agitator and the drum? I read a solution was to remove the agitator. I tried to unscrew it, but it's not budging.
There are 4 holes at the base of the agitator. Use a screwdriver to push in at each hole in order to pop the plastic grove that holds it in place. The agitator cap will then pull off to reveal 6 3/8" bolts. Remove these with a socket set and the entire agitator can be lifted to free the garment. To reassemble, position the agitator holes over the holes in the base, reinsert and tighten the bolts, snap the cap back on, and your are ready to go.
Jim
Jim!
Thanks for these instructions. It worked for me. I had washed a pair of shorts, with my driver's license in the pocket. The license had slipped between the wall of the washer under the agitator area. I took it all apart (Warning, if this is the first time that you're doing this, it's probably got some built up gunk inside) and lo and behold was my license. And assorted change, along with other miscellaneous items! Put it all back together, and all seems to be working well.
Washing machine is not working properly kindly advise who can repair in south delhi in Devli Village, Near Khanpur, New Delhi-110062
Agitator not working
the bottom will not come out
