Brother DCP-330C All-In-One InkJet Printer Logo
Posted on Dec 19, 2010
When i used to print its not printing blan page is coming out .Eveni cant able to print test page are all blank.just i replaced catrage
larry holland
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Dec 19, 2010
larry holland
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
384
Points
12
Did you remove the tape from the print catrage head "were the ink comes out of the cotrage".
Calibration ok but still prints blank pages
If the print tests are good, the only thing preventing your printer from printing is the print drivers. Download the latest correct drivers from Kodak's website and install them.
Printing blank pages
Press Test Page button on ur printer to check if there is issue with the software or printer.
If print test page is returning a printed page it means there is some problem in software communication with the driver.
1helpful
Have tried printing from computer and tried printing test page from printer. both times the pages come out blank.. how do I check the toner levels in printer. thank you
The draw back of inkjet technology printers are, if it is not using quite long period of time,cartridge nozzles will dry up, result printer will act just like a printing some thing but nothing will come on paper(blank page) even ink levels are showing full.
Try to recover the both cartridges through 'clean print cartridge' process from the system,if not better consult cartridge re-filler to clean the nozzles..Replace new cartridges if above said methods are not worked out.
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
I AM USING KYOCERA 8030 IT NETWORK CONNECTED EVERY TIME I PRINT IT PRINTS TWO BLANK COPIES WHY?
are you facing same problem with other document like notepad ...... please check it please ..... open a notepad type some thing like test print and give print and check its comes blank pages or not .... if its not coming please check the document setting how many pages your document heaving you can give number pages you want to print ....... if you facing same problem with notepad please post you comment ........... and try to uninstall the printer driver and reinstall it ..............
Prints blank pages
hi jcruisedirec
Test print shows that there is no problem with he printer.
Do this:
Type just one or two words in a new document and try to print. Before printing, look at the print setup and make sure you have the correct printer name selected.
Also when you go to print, there are few options like:
  • Print All
  • Current page
  • Pages
  • Selection
If you attempt to print "selection" without actually selecting a certain portion of the document, you get blank page.
So first check that the correct name of the printer is selected.
Then test printing one page
Hope this will help you. Good luck.
If you find this helpful, please give a rating
luciana44
Normal print results in a blank page
If you try and print a test page form the printer it will be light also. If this is the case you have a cloged cartridge. You can try to clean the cartridge, or replace it.
12helpful
3answers
Hp 1320 prints blank LOSER SPAM ALERT 1-800-532-4187
My HP 1320 printer is printing blank pages and it will not even print test pages etc
NO RESPONSE, PRINTER DISPLAY BLANK
sounds like you have a bad formatter....there is a way to circumvent the formatter and print whats called an engine test. this is used just to test the mechanics of the machine and leave the brain out of the equation...
Engine Test Button Location HP laserjet printer 5000 series
The engine test verifies that the print engine is functioning correctly.
The Formatter PCA is completely bypassed during an engine test.
This test is very useful for isolating printer problems. The engine test
prints a full page of lines across the entire printable area, and is also
useful for checking and adjusting registration.
laserjet-5000-engine-test.jpg Note Engine test will print from the last input tray used.
If the last input tray is empty or if the last input source was the duplexer,
then the Engine Test will print from Tray 2 (standard 250 CST).
If Tray 2 is empty (and the last input tray is empty or the last input source
was the duplexer), then the Engine Test will not function.
Printing an Engine Test HP laserjet printers 5000 series
To print an engine test, use a non-metallic object (such as a pencil) to
press the engine test button. A single test page with horizontal lines
will be printed. To print multiple test pages, hold down the engine test
button.
If the engine test prints ok then you have a formatter issue...if you have added memory or a network card try taking them out one at a time to see if the problem goes away. Otherwise the formatter will have to be replaced.
Inkworks
Norman Weimar
Norman Weimar
k24674
