SOURCE: old yamaha electric guitar
Santana's had quite a few guitars, take your pick:
1972 - Gibson Les Paul / Gibson SG Special with Humbuckers / Gibson L-6S
1975 - Gibson SG Special with P90 pickup (Woodstock Festival)
1976 - Yamaha SG 175B / Gibson SG Special with 3 Open Coils
1982 - Paul Reed Smith (PRS) Custom
1988 - PRS Santana II with PRS Santana III nickel-plated pickups and .009-.042 D'Addario strings
SOURCE: displays code Scn
Either the keyboard is disconnected or the Keyscan on the keyboard itself is but. More than likely a loose connector.
SOURCE: I have a Yamaha YPG-525. Everything is working
I have the same problem, mine is Yamaha YPG-625. This seems to be a common problem with Yamaha keyboards. I opened the 100 screws in the back, separated the main board from the display unit which is under it if you flip the keyboard upside down, to verify if there was any loose wires, nothing of the sort.
It is so frustrating, the keyboard is working fine but it is hard to navigate because the display is not functioning. Yamaha should do a recall as this is obviously something wrong with the keyboard happenning to a lot of people
SOURCE: The LCD has lines on
The defect is likely failure of the LCD module and the connections to the glass sandwich... it is likely fatal to the module... If you are adept with tools a bit, you can probably replace it yourself... You have to go slow and be careful to keep track of where stuff goes.
One has to be real careful to not damage the ribbon cables that connect between the upper and lower shell. I suggest having two people present to handle the shell when opening it. Have a good work surface and organizer cups or bins to keep screws seperate. There will be a LOT of screws from the back to remove to seperate the halves. DO NOT force anything.
You can probably order the part... Call Yamaha America Music support and ask for parts dept to order the part... I suspect it is a bit pricey. While your at it, inquire if they can sell you a service manual for the keyboard... they used to do this for $15 and you could get one with your order. The manual for the Tyros I got is very complete showing all the internal and assembly procedure.
SOURCE: Yamaha PSR-340 keyboard is not
a resistor or a capacitor has gone bad causing the faulty screen and the pop when shut off
