Ryobi Multi-Volt Battery Charger Logo
Posted on Dec 18, 2010
I need a manual for my ryobi charger part # 140237023
1 Related Answer
Jim Thurston
  • 672 Answers
  • Posted on Jul 04, 2009
SOURCE: NEED A MANUAL FOR A RYOBI BATTERY CHARGER
This link should help in finding a manual. Good luck. http://powertool.manualsonline.com/manuals/mfg/ryobi/ryobi_battery_charger_product_list.html
I have a P115 Ryobi Intelliport charger , will it charge the new lithium 18 V battery?
Ryobi P115 is an 18V battery charger. However, Ryobi Manual did not mention the current rating of P115. if the current rating of Ryobi P115 is 50% higher than your 18V Lithium Battery it will charge. but if it's less than or equal, it will not.
1helpful
2answers
Green light on new Ryobi charger flashing when trying to charge battery it that normal
Yes, the green light flashes until the battery is fully charged on Ryobi chargers. This will change to a solid green light when the battery is fully charged until the charger goes to a power-saving mode. Not all of the Ryobi chargers have a power-saving mode. However, for those that do, the green led will dim over time and then brighten and dim slowly again in this mode.
My Ryobi charger, model P113, actually has a key for the LEDs on the unit on the left of the battery port. The manual for this charger is here: https://manuals.ttigroupna.com/system/files/5495/original/P113_192_trilingual.pdf?2011 . Ryobi has many of their manuals on their site. Look up your charger/tool here: https://www.ryobitools.com/power-tools/support/manuals , Home Depot's web site also has many of these manuals on the product site for the tools that they sell.
I hope this helps.
Ryobi P110 chargers internal transformer is burnt out? what is the rating on it and where can i find it?
Unless you are a bit clever with electronics, better off buying a new charger than trying to fix the internal circuit on it. here is some links to info ive found.
a new Ryobi 18v li charger will charge your nicad battery but a nicad charger will not charge li-ion battery.
http://powertool.manualsonline.com/manuals/mfg/ryobi/p110.html?p=1
http://manuals.ryobitools.com/documents/2101
6helpful
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a Ryobi 18v battery charger model #1423701.....
http://oneworld1.inetu.net/manuals/ryobi/hp1442m_1802m_874_eng.pdf
It sounds like your battery is bad. If yellow and green are on for more than 15 minutes it probably a defective battery pack. See page 8 in the manual.
2helpful
RYOBI Charger problems
see you local ryobi dealer as this can be 2 different faults in the same unit.
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
