Heating & Cooling Logo
A
Anonymous Posted on Dec 17, 2010
HELLO , I HAVE A MONITOR 41 . RECENTLY I HAD TO REMOVE IT TO REPLACE THE FLOORING . I RETURNED THE HEATER TO IT'S LOCATION , NOW THE HEAT ONLY GOES TO 72 NOT BEYOND THAT . WHAT COULD BE WRONG? THANKS
Anonymous
Level 2:
Sergeant:
  • Expert 232 Answers
  • Posted on Dec 21, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
232
Questions
0
Helped
121145
Points
598
Did you reset the slider on the side of the heater? did you reset your set point?
  • killerinbed Feb 26, 2011
    i have set slide temp, burnr onleft starts but then shuts off and burner temp flashes
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
612
Points
11
Clean it out and make sure there's no leaks....
Monitor 422 Kerosene Heater. It runs for about an hour then shuts off.
Here is some information and your Service Manual with a Troubleshooting section.
cleanflametrap.com http://cleanflametrap.com > bruce_monitor
Monitor 422 · The Monitor is a computerized kerosene heater. · Here's an odd accumulation at the burner base. · Here the top panel is ajar and the upper front ..
monitor 422 specsmpi monitor 422 manualmonitor 422 heater troubleshooting mpi monitor 422 burner status flashingmonitor 422 partsmpi monitor 422 flame sensor
Monitor 422 Service Manual - ManualsLib
ManualsLib https://www.manualslib.com > ... > 422
View and Download Monitor 422 service manual online. MONiTOR HEATING SYSTEMS. 422 heating system pdf manual download. Also for: 22, 21, 41, 441, 40.
May 16, 2023 • Garden
Can't get power to the front panel even though power is showing in the wiring of the MPI 41onitor kerosene
It sounds like there may be an issue with the circuit board on your MPI monitor 41 kerosene heater. Based on your description, it appears that you've recently replaced the circuit board, but you're not able to get power to the front panel, despite power showing in the wiring.
There could be multiple reasons for this, and it is essential to investigate further. Here are some things you can check next:
  • Make sure that all connections are secure and properly connected
  • Make sure that the circuit board is the correct one for your heater model
  • Check the wiring, it could be loose or damaged
  • Check the fuses, they might have blown
  • Check the thermostat, it could be faulty or not connected properly.
If you have checked all these things and the issue persists, it's best to call for professional help as it may require specialized knowledge and skills to troubleshoot and fix the problem. It's important to note that working on heating appliances can be dangerous, and only qualified and licensed personnel should work on them.
I do not know if I will get an answer, but here it gos, my moniter heater cuts on, starts to heat up a little and then makes a small click noise and then shuts off
Remove Obstructions The overheated condition may be caused by obstructions blocking the air flow to the heater. Check: • The front of the heater • The circulation fan (on the back of the heater). • The flue pipe (outside) Step 5: Remove the Louver Remove the screws at the louver, and carefully clean.
Below is a link to your manual
http://monitorproducts.com/wp-content/uploads/M441OwnersManual.pdf
1helpful
Heat not working
Sounds like the air blend door is not opening to let heat in.
Engine coolant is provided to the heater system by two 16 mm (5/8 inch inside diameter) heater hoses. With the engine idling at normal running temperature, set the heater-A/C controls as follows. Temperature control to full Heat, Mode control to Floor, Blower control to the highest speed setting. Using a test thermometer, check the air temperature coming from the center floor outlets and compare this reading to the Temperature Reference table.
If the floor outlet air temperature is insufficient, check that the cooling system is operating to specifications. Both heater hoses should be HOT to the touch (the coolant return hose should be slightly cooler than the supply hose). If the coolant return hose is much cooler than the supply hose, locate and repair the engine coolant flow obstruction in heater system.
POSSIBLE LOCATIONS OR CAUSE OF OBSTRUCTED COOLANT FLOW
If coolant flow is verified and the heater floor outlet temperature is insufficient, a mechanical problem may exist.
POSSIBLE LOCATION OR CAUSE OF INSUFFICIENT HEAT
  • Obstructed cowl air intake.
  • Obstructed heater system outlets.
  • Blend-air door not functioning properly.
TEMPERATURE CONTROL
If heater floor outlet temperature cannot be adjusted with the heater-A/C control temperature control lever, one of the following could require service:
I have a Rheem Heat and air unit. Model # RGAC-080AW Serial # CM3D104 F4782 4794 and need to find out where the filter for the unit is located.
What filter are you talking about?
Air filter: Usually with a heat and air unit, the air filter is located behind the return air grill.
Return air grill looks similar to ordinary ceiling or floor grill where the hot or cold air blows into each room. Except the return air grill is larger and is usually put close to the heat-air unit.
Remove the grill and replace filter every 3-6 months.
If no filter is present, then dust and hair get stuck on the coils and unit will not meet temperature setting.
See image of typical air filter:
http://www.instablogsimages.com/images/2009/02/12/air-filter_IYR3W_69.jpg
How many sq feet will a 41 model heat?
It all depends on how well your house is insulated. A Monitor 41 has the same output rating as a Monitor 2400. It should heat around 2000 sq. ft.
18helpful
MPI 41 Keresene Monitor Heater LIft Pump over-primed?
I recently relocated monitor heater from living room to dining room and ran new line to heater. I have pressed the priming button located on right side and turn unit on, but all that happens is it will click on run for a cycle and burner never ignites and then turns itself off and burner indicator lights continue to blink on and off, I dont think it is getting proper fuel to unit. What do I need to do?
Monitor 41 oil heater stove lost its heat...
We repair Monitor Heater main circuit board and push button panel. call me at 800-782-4449 ask for Dima
3answers
Monitor Heater 41
Our monitor heater was reading E-01. We decided that we would try cleaning the back of the unit and we landed up cleaning all parts of the unit that were visible. We plugged it back in and it works fine again. Thank you for your time.
Top Heating & Cooling Experts
Paul Carew
john h
