Question about Broderbund PrintMaster Gold 16 for PC
I can't convert printmaster files to .pdf files with my windows 7 system. What can I do to fix this problem.
  • 3 more comments
  • mcdees2 Dec 17, 2010
    Your solution didn't work. Under item 3 you said to select "Broderbund PDF Converter v2.10d. I do not show this printer in setup name. Only amyuni document converter 400, microsoft xps document writer and my normal printer HP Photosmart C3100 series. I have tried to uninstall printmaster gold 16 and reinstall it but I still don't get the broderbund PDF printer. What now?
    I don't have broderbund PDF converter listed on my printer setup name or in listed printers on the devices and printers in my windows 7 system. I have tried to uninstall my printmaster gold 16 and reinstall it but to no avail. How can I get that printer driver installed on my laptop?
    This is the same solution I got from NinaE. It didn't work then and it wont work now! I also got one from her suggesting adding a new port for a broderbund pdf printer. I still don't show a broderbund pdf converter or printer anywhere. I need to find this driver somewhere. Is my printermaster gold 16 incompatible with windows. Everything else seem to work ok. It worked fine on my xp computer.
  • mcdees2 Dec 20, 2010
    As I have stated before, I do not have a broderbud pdf converter v2.10d installed in my device and printer file or anywhere else. When I go to printer setup it is not listed under name. I have tried to locate this software on the internet but with no sucess, I just keep getting the run around and end up with trial version programs.
    I really believe that the printmaster gold 16 program is not compatable with windows 7. What do you think?
    Do you people read the replies that I send back. I have told you trhat I don't have a broderbund pdf converter verson any number. You keep telling me to select that printer and I don't have it. If you have something new then send it otherwise go back to sleep and don't bother me anymore.
  • 1,216 Answers
Here is a step-by-step description of how to use the Professional Printing option to convert PrintMaster files to PDF:
1. In Tools/Options/General Options, check the box beside "Optimal Printing Resolution".
2. Go to File/Printer Setup/Printer Setup.
3. Under "Name" select Broderbund PDF Converter v2.10d
4. Next, go to File/Professional Printing.
5. Select "Save As PDF".
6. At the next screen, type the name of the PDF file you want to save in "Project Name".
7. Under "PDF Resolution", select 600 dpi.
8. Click on "Save As". In the next window, browse to the folder in which you want to save the file (for example: My Documents).
9. Click on the "Save" button.
10. PrintMaster will save the PDF file to the folder you selected.
11. Open the file in Adobe Acrobat to make sure all the elements and pages are there and that it looks as expected.
12. Once you are satisfied, upload this file to Print Pelican.
There are two caveats: 1. Because it is made to print cards and calendars to your laser or ink-jet printer, PrintMaster expects page sizes to be standard ones such as 11" x 17" or 8.5" x 11". Custom page sizes (such as 7" x 10") may not work properly. 2. Do not use backgrounds or elements that print to the edge of the page. This is a feature that will not print properly from PrintMaster. Make sure your pages have white margins with nothing printing on them.
Posted on Dec 18, 2010
  • 3,530 Answers
Welcome to Fixya
Here is a step-by-step description of how to use the Professional Printing option to convert PrintMaster files to PDF.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Dec 17, 2010
    President:
  • 3,278 Answers
Hello.
Here are the steps:
If this doesn
  • NinaE Dec 17, 2010
    Hello, again.
    Here's a solution from Broderbund Support:
    The Broderbund PDF creator requires that the user add a port to allow the program to function on Windows 7 64-bit. The installer does not make all of the necessary changes for the user. If the user does not make these changes, the application will become unresponsive and crash beginning the pdf creation process.
    The steps to repair this issue are:
    1. Open Devices and Printers from the Control Panel.
    2. Right click on Broderbund PDF Creator.
    3. Click on Printer Properties.
    4. View the Ports tab.
    5. Click on the Add Port... button.
    6. Highlight "Local Port" and click on the New Port... button (Not New Port Type...)
    7. Enter any name for the port.
    8. Restart Your Computer
    9. Return to the application.
    10. Save your project as a PDF.
  • NinaE Dec 20, 2010
    So, when you select:
    Under "Name", you don't see Broderbund PDF Converter v2.10d as a selection ?
    That seems to be the only way to save a Broderbund file to PDF in Windows 7.
6ya staff
SOURCE:
How to convert pdf to pmx file
I wonder whether there are any differences between the pdf converter I am testing these days and the one you mentioned above?
How to Convert PDF to Image in NET
Feb 22, 2013 | Broderbund PrintMaster® Platinum 17 Full...
Converting files in printmaster to pdf files and as it switches over to converting, it goes to a printing in broderbund box and screen freezes and shuts down the program
I'm not familiar with the conversion in Printmaster, but here is a simple solution:
You can use Cute pdf writer.
Go to www.cutepdf.com and download the free utility. The nice thing about this is it will work as a "printer" for anything on your computer you need to print--in pdf format.
In essence, it becomes a printer--you choose to print whatever it is you normally print and chose cutepdf as the printer and it prompts you for a file name and there you go!
Aug 22, 2011 | Broderbund PrintMaster® Platinum 17 Full...
I have Printmaster Platinum 15 installed in an older computer (xp) and can convert a file to PDF. I installed it in a newer one (Windows 7) and cannot convert to PDF. I get something that says "Unable...
download pdf995 onto windows 7
http://www.pdf995.com/
it will install there are two files you have to install
once installed it will look like a printer to your program and then print to the pdf995 printer and it will convert whatever you print into a pdf file.
Nov 27, 2017 | Broderbund PrintMaster Platinum 15 Full...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
I could not install PrintMaster Publishing Suite 7.0 on our new computer running Windows 7. Is this software compatible with Windows 7? Is the a version to upgrade to that is compatible that we can work...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Jun 20, 2010 | The Learning Company PrintMaster...
I bought a new computer with Windows 7. Is Printmaster 18 compatible? I have started to install it but a message came up stating there were 'compatibility issues' Is this correct and if so, what can I do?
This should answer your question
I understand that you are inquiring if Printmaster 18 is compatible with Windows 7. Our developers have tested every aspect of Printmaster 18 to see if it will function properly on Windows 7. It has passed all tests except one, which is the Save As PDF feature. Our developers just became aware of this and are working on a resolution to make it work on the Windows 7 operating system. We apologize for any inconvenience this has caused, but we can assure you that we will provide a fix for this as soon as possible.
http://www.broderbund.com/store/broder/Content/pbPage.ProductSupportMain
Jan 10, 2010 | Broderbund PrintMaster Platinum Version 18
Printmaster 17 does not save as pdf files under
Here's my solution: Don't waste your time and money on, use a program other than PrintMaster! PDF is universally accepted across formats/browsers/OS ...what kind of program would not export THE most commonly used format????
Dec 15, 2009 | Broderbund PrintMaster® Platinum 17 Full...
Cant save to pdf in printmaster gold 17
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
Jan 28, 2009 | Broderbund PrintMaster Platinum 16
I have the Printmaster Platinum Version17 , I cannot save to pdf files?
Jul 28, 2008 | Broderbund PrintMaster Platinum 16
Broderbund PrintMaster Gold 16 for PC Logo
3,890 people viewed this question
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Ekse
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
