SOURCE: sound card problem for intel desktop board D101GGC
SkullyFox give the good solution but let me tell you one thing.....
If you by mistake installed the wrong drivers in the Realtek chipset sound then you have to remove or uninstalled the sound application …..
Intel Original all the boards having the same problem ….
Over the internet one patch is available for Realtek sound drivers first you need to install that patch after this also sound not came then try re-installing the Sound application…
SOURCE: motherboard Intel D101GGC no display
Hello dheyx, your Intel D101GGC board used an intergated ATI Radeon Xpress 200 graphics. If you lost display than you're intergated Radeon has died. Suggest you replace it with a
PCI-E X16 graphics card. The Intel D101GGC board does have an opened X16 PCI-E slot. Do not forget to change the bios video card setting. You want the board to see& load the PCI-E first.
SOURCE: d101ggc
Unplug all cards and in case uninstalled the grafik card.
Then check your memory modules.
If one module is defective or it has contact problems you will get no display and a beep.
I think it's a good idea to uninstall and reinstall the RAMs.
If the beeper sounds further, change the RAMs.
try this link.. http://www.userdrivers.com/Motherboard/Intel-D101GGC-Desktop-Board/download/
