Question about HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard
I have HP DV2000 and its screen split into 6, it occured when i was doing my job on the laptop and suddenly the screen halt and then it show the message memory dumb and then when i restart it the screen was split into 6.
My hp pavilion dv9000 laptop showing 6 split screens always.please let me know is this a hardware or software problem?
If the screens are 6 individual screens you have a software problem
Go on any one of the screens and hit the Right mouse/touch-pad button to get into screen software
Feb 23, 2011 | HP Pavilion dv6000t 15.4" Notebook Laptop...
Hi, i have an HP Pavilion dv2000 & it had recent motherboard problems, so I had it repaired in the HP Service Center. They replaced the motherboard & so far, everything was okay until yesterday....
Yes, the GPU is faulty. either replace the systemboard or reflow the GPU. Second option is cheaper and you can do it yourself. There's a link for a diy guide to fix that issue.
does your screen look like this?
http://bootmylaptop.com/hp-pavilion-dv2000-with-display-issue/
Jan 30, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a dv2000. It turns on, but see no bios screen.
TRY TO GO THE BIOS SETTING THEN LOAD DEFUALT.. IF THE LOGO SCREEN NOT SHOW SOME PROBLEM FOR THE DISPLAY THE DEFAULT SETTING IS THE LOGO SCREEN WILL SHOW ON START UP THE SCREEN..
CHECK THE DISPLAY,,,, INVERTER, OR VGA CABLE,, VIDEO CARD..
Jun 25, 2009 | HP Pavilion dv6000z Notebook
My dv2000 boots but screen is split into like 8 parts (each part showing same thing) there are some wavy lines..sometimes its ok ...i try to load windows vista recovery (from partition) - it crashes on...
I have the same problem that my screen splits into 6 but occasionally screen comes normally. I gave to HP service center and they told me to change my mother board. I was worrying about the cost of Mother Board bcoz it costs 1/3 of my purchased rate and also my warranty was expired just 2 months before.
So, I tried some way to fix this temporarily, while screen comes normally, I went to Safe Mode, it works fine. So, I got an idea, it works in less hardware access, I think, how it works when removing NVIDIA display driver. So, I removed it. Now, it works fine but there is a difference in display but that doesnt matter while comparing previous.
I'm still searching permanent solution. I'm planning to change the Hardware of NVIDIA card. Lets see,
Jan 19, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Hp dv2000 error code 104- unsupported wireless network device detected system halted
The user has not described the operating system in use.
However this problem generally occurs due to incompartible hardware. in this case it is ever stated. ie. Network interface Device. I suggest you disconnect the Network devices including cables, then try to reboot.
If not descibe how far the booting process gets and type of network hardware connected and operating system to your system
Heruless
Nov 07, 2008 | HP Compaq Presario V2000 Notebook
Hp pavilion dv2000 no lcd dispaly
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Sep 24, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
LAPTOP HP PAVILION DV2000 problem
Hello!
That beeps indicated that there is a problem in the video Graphics adapter and in the memory.
try remove and clean the memory and then fix it back, im sure that would resolve your problems. however if this not solve then your should replace the memory.
If affraid to do so, then maybe let the repairman do it for you.
fixya!
best regards, melnavz
Feb 29, 2008 | Computers & Internet
HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  Logo
451 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
