"F2" means you have a shorting membrane keypad. The "Pan Heat" key is shorting.
On these models, the membrane keypad is not available as a separate part,
so you would have to order the control panel frame assembly which comes
with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find
helpful exploded view diagrams and order parts by entering your full
model number* from the tag on the oven here.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors may have a lock:
* The exact part number you need will depend on your exact model number. Models in that series are shown below:
KHMS155LBL0
KHMS155LBL1
KHMS155LBL2
KHMS155LBL3
KHMS155LBT0
KHMS155LBT1
KHMS155LBT2
KHMS155LBT3
KHMS155LSS0
KHMS155LSS1
KHMS155LSS2
KHMS155LSS3
KHMS155LSS4
KHMS155LWH0
KHMS155LWH1
KHMS155LWH2
KHMS155LWH3
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
