Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
Posted on Dec 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Mitsubishi electric Mr. Slim ductless heat pump, 2 years old and the inside unit just started making a humming noise, just loud enough to bother you. The unit worked all summer real well and into the winter is when we noticed the noise. Thanks, Greg
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Dec 17, 2010
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
953012
Points
6173
Please check your indoor motor's mechanism is faulty. Or capacitor(condenser) of fan motor is weak. Replace it.
2answers
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
http://www.ehow.com/info_12016541_particles-blow-out-fan-air-conditioner.html
Noise from the indoor unit of Mitsubishi MS09TW
My unit is a 3 year old Mitsubishi and it started making the humming noise you described. It is quite high and I finally got up on a ladder to have a look. It is the water pump making the noise in my case. It seemed like it was pumping a little too much water out. I undid a screw and angled the pump slightly and problem solved.
hope this makes sense and helps a little.
Mr slim ticking noise
Open it and take a look, it could be debris or a loose wire.
1helpful
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
2helpful
2answers
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Mr. Slim MSY-A17NA noisy interior fan
If the inside fan got loud because it developed mold, the only cure is to keep cleaning it.
2answers
Ductless heat pump systems
Heat pumps do loose their heating capacity and efficiency as temps drop. If you decide to rely on a heat pump you may want to make sure that your system has a back up heat strip, maybe even controled with an outdoor thermostat, if that is an option. The Mitsubishi is a great product.
Top Mitsubishi Heating & Cooling Experts
 Mikey
Mikey
vince
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
